Hey guys the electronic fan speed control on my 06 King Ranch Expy has started giving me trouble.
I can't adjust the speed anymore. The display will show an increase and decrease when I push the rocker switches but the air flow is alway full blast. I sometimes have to go up to full blast to get it to kick on. The temperature control still works as does the location switches.
If I press the off button the display goes black like its turned off but all the air switches to the deforst vents, which I understand is the neutral position for the location.
If I turn the system off and shut the vehicle off then turn it back on the air will remain off until I turn it back on again, at which point I get full blast air speed again.
Since this started about 4 months ago it has worked normally for like 2 or 3 days but only for one start up / shut off cycle and never twice in a row. These were all on sepearate occasions.
Does anyone have any idea? Is there a module that controls the fan speed on the inside that I can replace. This also seems to only effect the front vents. I belive the controls for the rear vents still work normally. But I will have to double check that.
