expo dude
I have recently with in the last 6 months flushed my whole cooling system, changed the thermostat and replaced and flushed the radiator for a bit seems like the heat came back for that day I replaced all the coolant and flushed the system but it gradually started to lave low heat in the truck this truck also has rear heat and air too. like I said flushed from front to back could the water pump be worn at the impellers causing a low flow to the whole system the truck don't over heat or run hot it just don't heat up well inside the truck passenger area.
