Go Back   Ford Expedition Forum > Ford Expedition Forum > Electrical
Register to remove these ads.
Electrical
door ajar sensor
This is a discussion on door ajar sensor within the Electrical forums, part of the Ford Expedition Forum category!
I'm guessing a stealership is the only option to replace one of these? The rear passenger door taint working....even after ...
Reply
Old 09-04-2010, 08:00 PM   #1 (permalink)
Registered User
Default door ajar sensor
I'm guessing a stealership is the only option to replace one of these? The rear passenger door taint working....even after a can of WD Don't see anything on Ebay. Has anyone ever changed one? It's an '03 XLT FourX4.
krakoosh is offline   Reply With Quote
Old 09-04-2010, 10:17 PM   #2 (permalink)
10K-Watts's Avatar
Super Moderator
Default
nope...i have an 04 EB
__________________
04 EB/26" Gianelle Mallorca's/Lexani 305-30-26 tires/5&15% tint/35% windshield+visor/billet UPR-LWR grille/IPCW LED Black Tails/SICK HID's Retro 6K head&fog HIDs/Flowmaster Exhaust/K&N Intake/Power Stop drilled&slotted rotor kit/Superchips Vortex 1950/Pioneer AVIC-D3 Nav/DVD/BT/Boss 15" w/DVD player/12" headrest/2-18" PSI Audio/8 Massive Audio 6.5/3 Nx4 amps/4 Skar Audio 8"/2 Skar Audio 4500.1 amps/Patriot Decals/PTM hitch cover/Eibach Anti-Sway Bar/2" Ground Force drop springs/Suncore conversion
BKA...FREEWAY...AKA...BHSoulja
HOLY ROLLERZ CHRISTIAN CAR CLUB (HRC3) National Member
10K-Watts is offline   Reply With Quote
Old 09-05-2010, 12:30 AM   #3 (permalink)
KWT2000's Avatar
Default
dorman makes an aftermarket switch there like $9 on ebay... you have to remove the door panel and remove the switch from the door catch.mechanisim
__________________
IM GOING TO PRESS "3" BECAUSE I WANT YOU TO LEARN ENGLISH!!!
1997 EXPY E.B., 6" LIFT, 35's, JET TUNER, REAR CAT DELETE, ELECTRIC FAN'S, XM RADIOSOLD 12/12/2011
Official Member Of The RED EDDIE BAUER Club
Official Member Of The LIFTED EXPY Club
CALL IN WITH EXPLOSIVE DIAREAH, THEY WON'T QUESTION IT!!!
KWT2000 is offline   Reply With Quote
Old 09-05-2010, 12:43 AM   #4 (permalink)
ELVATO's Avatar
Super Mod
Default
These instructions are from the service manual. Follow them at your own risk. I am not responsible if you break anything.
With that said:
For the door ajar switch in the rear door, follow these instructions:
1. Remove the door latch. (see below)
http://i96.photobucket.com/albums/l1..._gifgenref.gif
2. Remove the door ajar switch.
-Release the door lock actuator locking tab.
-Remove the door lock actuator.
-Release the locking tab and remove the door ajar switch.
3. To install, reverse the removal procedure.
These are the instructions on removing the rear door latch.
NOTE: The rear door window glass must be completely raised.
1. Remove rear door trim panel.
2. Position the watershield aside.
3. Remove the childproof door lock cover.
4. Disconnect the exterior door handle actuating rod.
-Open the clip.
5. Remove the bolts and position the rear door latch aside.
-Discard the bolts.
6. Disconnect the electrical connectors.
7. Release the interior door cable and remove the rear door latch.
-Position the cable cover aside.
-Release the conduit and the interior door cable.
8. To install, reverse the removal procedure.
-Transfer parts as necessary.
-If necessary, use multi-purpose grease to lubricate the latch.
__________________
I'm not responsible if you break something :)
ELVATO is offline   Reply With Quote
Old 09-05-2010, 06:34 PM   #5 (permalink)
Registered User
Talking
-Open the clip.
-Discard the bolts.
I would never hold you responsible but I may have Bubba and or Vito come knockin on your door Thanks for the reply but that seems to be for the liftgate...mine's the passenger side rear door. I shall get me a manual/disc from Ebay soon
Old 09-05-2010, 06:40 PM   #6 (permalink)
Registered User
Default
Thanks, I'll go look for that then. I had it apart but didn't want to go much further right now...had a BBQ/partay to go to:) It didn't seem to want to come loose from the handle and the lock rod....I will tackle it early one morning.
Old 09-05-2010, 08:27 PM   #7 (permalink)
ELVATO's Avatar
Super Mod
Default
Liftgate? Liftgate doesn't have a child lock ;) The manual you buy will be the same as mine, and that is what it says :)
__________________
Old 09-05-2010, 08:34 PM   #8 (permalink)
Registered User
Default
rear door? hatchback? the one that lifts toward the sky? not sure what you mean by childlock or what those have to do with my problem but yes, it doesn't have one. the two rear doors do tho. the rear passenger side is the one acting up. lights don't come on when the door is opened. the sensor be jacked up me thinks:D I'll need a manual for other projects anyway.
Old 09-06-2010, 01:22 PM   #9 (permalink)
ELVATO's Avatar
Super Mod
Default
Liftgate/hatch/door that open to the sky is the same thing.
The instructions above are the rear passenger door. My liftgate comment stems from step 3 of the second set of instructions. It says to remove the child lock cover. The liftgate doesn't have a child lock, where as the rear passenger door (2nd row door) does. It was my way of saying that the instructions are correct for the rear passenger door that you requested... ;)
In the manual, it will refer to the liftgate as the "liftgate" and the 2nd row doors as the "rear doors".
__________________
Old 09-06-2010, 03:00 PM   #10 (permalink)
Registered User
Default
Gotcha. Well, thanks for your time and the help
Now, the the dash light isn't on but opening the door doesn't activate any lights. Any thoughts on that?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
