So I'm new to this stuff. What is it?! Is it just the spray? Will it work to cover those goofy ass stock "chrome" painted wheels on a 2000 expedition EB?
It's almost like a spray on rubber/plastic coating. It will spray on similar to a spray paint, but the coating once dry will actually peel off if you want. Google it, for the price and reversibility it cannot be beat.
And YES it will cover your wheels, about 1 can per wheel usually
Pretty much yes. Like anything else, the cleaner the surface the better is adheres. If it is something you might want to remove down the line, clean thoroughly and wax prior. If done correctly if should last a while and peel off when your done. If you are not used to spraying I would practice on trash first.
