Go Back   Ford Expedition Forum > Ford Expedition Forum > General Discussion
Register to remove these ads.
General Discussion
2001 expedition wont start but turns over
This is a discussion on 2001 expedition wont start but turns over within the General Discussion forums, part of the Ford Expedition Forum category!
My 2001 expedition had been acting up for a while sometimes it didnt want to start. then one day when ...
Reply
Old 02-21-2012, 07:33 PM   #1 (permalink)
Registered User
Unhappy 2001 expedition wont start but turns over
My 2001 expedition had been acting up for a while sometimes it didnt want to start. then one day when i got home from work it was idling funny so i gave it alittle gas and it died and ive only got it to start 1 time since, but you had to keep your foot on the gas to keep it running. It turns over but wont start at all now it seems to be draining the brand new battery that replace a couple months ago can get it started to take it somewhere to get it hooked up for a code. If someone could please give me some insight on what may be going on. I know the best thing is to get it hooked up and find out whats wrong.
sherry04 is offline   Reply With Quote
Old 02-23-2012, 08:32 PM   #2 (permalink)
Registered User
Default
please could someone please help me....Im a single mother of 4 children dont know have anyone to look at it and not much money..please answer ...
Old 02-23-2012, 09:02 PM   #3 (permalink)
toms89's Avatar
technical advisor
Default
We don't have alot to go on with the little info given but it sounds possibly fuel related?! Did it act like it was running out of gas?? You can turn off stereo and accessories and see if you can hear fuel pump running for 2-3 seconds when you first have key in run position. (do not crank) It may be hard to hear.
__________________
Blown 2000 XLT 4wd...12.61 @ 107.44mph. (481 rwhp & 577 rwtq)
http://www.youtube.com/watch?v=QW7XKRvOP0Q
Built 5.4 w/ 8.6 to 1 comp, forged manley rods & pistons, forged steel crank, comp cams 102500, trick flow heads, ported lightning supercharger assembly pullied for 14psi boost. Tuned by self via SCT pro-racers software.
Built 4R100 . Complete custom mandrel bent dual 3" stainless exhaust with high flow cats.
toms89 is offline   Reply With Quote
Old 03-04-2012, 04:58 PM   #4 (permalink)
Registered User
Default
It sounds like its getting no gas. we did try to hear fuel pump but couldnt hear it. A friend of my father came over and said it was the tming but I had a vehickle where it was the timing and when it was that it had a real fast winde but the expeditions not doing that it just keeps turning over but wont start.It has a new battery, new alternator, all 8 injectors or what ever they r ( modulators I think they call them). I think its something to do with the fuel also. cause I was running the gas pretty low because didnt have alot of money for gas because of gas prices. So I thought maybe I clogged the fuel filter then it caused the fuel pump to go out.
Old 03-05-2012, 04:55 PM   #5 (permalink)
Registered User
Default
My 2002 has had the same problem. I recently changed the fuel pump relay, and that worked for a while. This morning it wouldn't start for my wife. It, too, has a new alternator & battery. I guess I'm down to the question of fuel pump and filter.
stansawyer is offline   Reply With Quote
Old 03-05-2012, 07:56 PM   #6 (permalink)
ELVATO's Avatar
Super Mod
Default
Changing the filter would be the quickest and cheapest item to check off.
So when you have someone turn the key, and you listen to the engine, you don't hear the high pitched whine of the injectors priming?
__________________
I'm not responsible if you break something :)
ELVATO is offline   Reply With Quote
Old 03-05-2012, 08:28 PM   #7 (permalink)
toms89's Avatar
technical advisor
Default
Running on fumes is bad for the fuel pump as it uses the fuel to cool it.
If you have the means check fuel pressure at the rail.
If not you can remove gas cap and listen closely as someone first turns ignition to run position but do not crank. Pump should run 2-3 seconds. This can be repeated as necessary and should be able to determine if fuel pump is working. If you get dead silence pump or wiring may have failed. If you hear muffled whine its likely ok.
__________________
Old 03-06-2012, 01:00 AM   #8 (permalink)
Registered User
Default
Dont forget the Inertia shutoff switch.. Stops the fuel pump and I have seen a LOT of them go bad. On my old 2001 explorer it was in the passenger kick panel, but not sure where it is on the Expy. Find it, (Anyone know where it is?) and push the switch or jumper across it (To TEST only). If it works, REPLACE the switch because it will leave you stuck again.
For those that do not know, the inertia switch will shut off the fuel if you are in an accident or jarred pretty hard, however these spring loaded switches can and DO go bad even without an accident, causing the fuel pump to stop running. I have seen these be intermittent also.
KC Dave is offline   Reply With Quote
Old 03-06-2012, 03:08 PM   #9 (permalink)
Default
one quick and easy check is to find the fuel press port [looks like tire valve] on the fuel rail. now depress the little tab in the center tab fuel should gush out, now turn key off and on several times and try again. there should be a lot come out if not pump is probably bad.
__________________
98 EB 5.4 4x4 florida Ford SMT
86 samurai
86 mustang gt
CARO'S98EB is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
