2008 burning oil
Edmaude
Nj
We purchased our truck with 16k as a certified used from ford. Overall I really like the truck, but notice it is burning more than a quart of oil between 3k changes. Dealer claims this is within spec, but I am, not thrilled such a new motor is doing this.
We have 22k on the truck now and have plenty of power train warranty left.
Anyone else having same issues?
panda24619
San Diego
no it dosent. i burn about a quart or so every 3000 miles. my moms 4runner and dads tundra dont burn any at all. if i were you i would just not change the oil and be like whts this? make them put a new engine in it.
bring_em_on
MD
That doesn't sound right to me either. I had an issue similar to this but it was my own fault. I have an '05 XLT 5.4. My manual calls for 7 qts of oil but me being the genius that I am didn't read the manual and was only putting in six. So I noticed that at my oil change time I was low on oil. Once I actually read the manual and started doing the 7 qts, well, hallelujah it didn't burn the oil.
Eric
I had a Chevy Tahoe that burned oil from mile one, it was about 1 quart down at the 3,000 mile oil change. I complained about it to Chevy countless times and the response was it was within spec. As I stacked on the miles it got worse and worse, around 45,000 miles it was burning a quart every 1,500 miles so the dealer was able to get authorization to change the valve stem seals. That did not fix the problem (I new it was rings). Again was told they were going to do nothing after I had sent several letters to the corporate office.
Then one day I tried a new Chevy dealership service dept. Come to find out if you have an agressive dealership who will fight GM for you then you are much better off. The new service dept. manager felt the same as me that it was not right. So they did an oil consumptin test where they seal the drain plug and dip stick. After 1,000 miles I bring it back and it was down nearly a quart. After a short wait I get a call from the dealer advising they received authorization to install a new motor. So it took me 4 years and 60,000 miles to get the probelm fixed.
The point to the story, I was told by the service manager that it made it much easier for him to get the motor as I had meticulous records of every oil change and how much the oil was down, I had created a record of complaints regarding oil consumption from the beginning, and lastly I found a good service dept. willing to go to bat for me.
So my guess is your oil consumption will only get worse over time, it may be in spec now but what will it be at 50,000 miles? Get on them and stay on them about it.
