Go Back   Ford Expedition Forum > Ford Expedition Forum > General Discussion
Register to remove these ads.
General Discussion
5 Lug to 6 Lug
This is a discussion on 5 Lug to 6 Lug within the General Discussion forums, part of the Ford Expedition Forum category!
Has anyone ever tried to convert their 5 lug expy's to 6 lug, so that some of the newer wheels ...
Reply
Old 04-05-2007, 05:03 PM   #1 (permalink)
Registered User
Default 5 Lug to 6 Lug
Has anyone ever tried to convert their 5 lug expy's to 6 lug, so that some of the newer wheels can be used on their expy? I currently have a 97 4x4 expy XLT and would like to know if anyone has attempted to try this.
Blackhoney is offline   Reply With Quote
Old 04-05-2007, 05:12 PM   #2 (permalink)
green03's Avatar
Default
Not sure on this one because the rear on the 6 lug expeds is independent rear suspension that have a half shaft instead of a solid axle. You would have to do alot of conversion to get the 6 lug pattern in the rear using some kind of factory parts. Aftermarket would be able to custom make you some different rear axles, but then you would have to fabricate up the brake system up and adapt the rotors.
Just not worth the trouble IMO unless you have something bigger planned other than needing an extra lug....
Matt R
__________________
Matt Robinson
Green 03 XLT 5.4 4x4
Powerdyne Supercharger 9lb (kit homemade) (intercooler coming soon)
Built 4R70W With Alto Red Eagle Clutches and Kolene Steels
Baumann Shift Kit
PI Stallion 10.5" Converter With Triple Disc Lockup Clutch
Magnaflow Muffler/Twister Resonator 3" Pipe
Equal-Length Y Pipe and High Flow Cats
NGK Iridium TR6IX Plugs and Granetelli zero ohm boots.
Custom Sniper Tune by Matt Robinson
Factory F150 18" Wheels
green03 is offline   Reply With Quote
Old 04-05-2007, 07:43 PM   #3 (permalink)
Default
Green his 97 has a solid rear axle but I agree that it is likely more trouble than it's worth, especially just to expand wheel choices.
__________________
***SOLD*** 97 Expy XLT 5.4L | ATI Procharger | 10.5 psi | 4.10 LSD | Art Carr valve body | 18-inch Lightning wheels | Magnaflow duals | 2 Magnaflow cats | Fuzzy dice ***SOLD***
pronstar is offline   Reply With Quote
Old 04-06-2007, 09:30 PM   #4 (permalink)
Registered User
Default
Correct me if I am wrong. If I upgrade wheels don't I have to go with bigger brakes any way?
Old 04-06-2007, 10:10 PM   #5 (permalink)
Default
Well, you can spend the big bucks and get larger brakes to go with your larger wheels. The starting point for larger brakes on your truck is about $2,000.
Newer trucks may be able to use Baer's EradiSpeed plus kit that includes larger rotors and a caliper-relocation kit, for about $800 or so. I know they have it for the newer F150s, not sure about the Expeditions. But they definitely don't have it for your truck, because I'd have it if they did!
You can also upgrade your rotors and pads like many folks do, including me. These bolt right up just like the OEM parts.
Or you can do nothing like most people do.
At any rate, rotor upgrades don't change the number of lugs.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
