Go Back   Ford Expedition Forum > Ford Expedition Forum > General Discussion
Register to remove these ads.
General Discussion
98 expedition Heater problems
This is a discussion on 98 expedition Heater problems within the General Discussion forums, part of the Ford Expedition Forum category!
I have searched high and low for a solution to this problem and have found nothing so if i missed ...
Reply
Old 11-06-2010, 07:50 PM   #1 (permalink)
Registered User
Exclamation 98 expedition Heater problems
I have searched high and low for a solution to this problem and have found nothing so if i missed something I apologize ahead of time. Recently Ive let my truck warm up for awhile say 15min get in and drive the heat is nice and warm for 10 min or so then the heat begins to blow cold and the engine temp guage spikes like the truck is overheating the truck starts to run like garbage no power not missing or anything so i assume it goes into fail-safe mode then just as quickly as it started the heat is back and the truck is running fine then shortly the cycle will repeat itself. The thermostat has been changed and we tested the heater core for flow. Im sort of thinking cht sensor or ect sensor, any suggestions would be appreciated.
Thanks,
Brandon
bschmitt07 is offline   Reply With Quote
Old 11-06-2010, 07:58 PM   #2 (permalink)
Registered User
Default
I forgot to add that when the truck "overheats" that the oil light comes on and the check engine light comes on and i tryed to pull the codes and it says no codes stored so that was a bust
Old 11-07-2010, 12:00 PM   #3 (permalink)
Registered User
Default Sounds wild but..
Hi
I'm probably way off but these are similar symptoms to coolant getting into the engine via a cracked block or such like.
Does the engine run rough ?
How's your oil look ? Is it getting like a creamy look on the filler cap ?
Is there excessive steam in the exhaust back at the tailpipe ? Can you detect the smell of antifreeze in your exhaust ?
Can you see air bubbles coming back into your coolant resevoir ? How's that coolant level, do you have to keep topping it up ?
__________________
1998 Expedition Eddie Bauer 5.4L in Black
2W, All W, 4H, 4L drive options
Purchased in '08 at 22000 miles genuine, in great shape.
gazbold is offline   Reply With Quote
Old 11-16-2010, 06:29 PM   #4 (permalink)
Registered User
Default
theres no smell the oil looks fine we flushed the system to try and remove any air bubbles and that didnt help at all and it only runs bad when all the dash lights come on and the heat goes cold but even then its not rough it just has no get up and go
Old 11-16-2010, 07:40 PM   #5 (permalink)
Default
Could be the water pump impeller spinning on the shaft or just going out under load. This allows it to overheat and set off all the lights then the ECM goes into "limp" mode. ??
jeff1998 is offline   Reply With Quote
Old 11-16-2010, 09:59 PM   #6 (permalink)
Racenut's Avatar
Default
I definatly agree with Jeff's post it could be the water pump or even though you have had the thermostat changed, you could have gotten a defective T - stat ( Have seen this happen on more than a couple of occasions ). When the thermostat was changed, was there a gasket used, or was RTV silicone used? ( Have also seen to much RTV used and it will squeeze into the thermostat and cause it to stick ).
__________________
______________________
2002 Expy EB 5.4L 2wd
CAI
Flowmaster 70 series
Rear cat and Y pipe delete
Smoked corners, tails, and third brake light
2 Hella 500 FF behind grille
8000K HIDs Heads and Fogs
Soon to come
Shorty Headers
3.5" Fabtech 2wd lift kit
33" Tires
Racenut is offline   Reply With Quote
Old 11-19-2010, 10:19 PM   #7 (permalink)
Registered User
Default
ok so today while driving the check engine light came on and stayed on so i took it to autozone and it said cylinder 4 misfire changed the plugs and it seemed to alleviate the problem some but seems to start to miss under load like going up hill. On the agenda for tommorow when the parts stores open is a. thermostat b. water pump and c. coil packs? possibly wires as well....any thoughts?
Old 11-19-2010, 11:20 PM   #8 (permalink)
KWT2000's Avatar
Default
coil pack or packs for sure and a t-stat i don't think you need a water pump
__________________
IM GOING TO PRESS "3" BECAUSE I WANT YOU TO LEARN ENGLISH!!!
1997 EXPY E.B., 6" LIFT, 35's, JET TUNER, REAR CAT DELETE, ELECTRIC FAN'S, XM RADIOSOLD 12/12/2011
Official Member Of The RED EDDIE BAUER Club
Official Member Of The LIFTED EXPY Club
CALL IN WITH EXPLOSIVE DIAREAH, THEY WON'T QUESTION IT!!!
KWT2000 is offline   Reply With Quote
Old 11-20-2010, 01:32 PM   #9 (permalink)
Registered User
Default
to late water pump is done put another new thermostat in and same problem. Im almost thinking about doing a compression test to see about a blown head gasket.
Old 01-03-2014, 02:56 PM   #10 (permalink)
Registered User
Default
Hi Brandon, I have a 1998 Ford Expedition with 4.6 V8 engine and I am having exactly the same problems with my heat, temperature gage spiking up and truck starts running like crap... I have searched everywhere to find a solution to the problem and can't seem to get it fixed. I changed thermostat, new radiator cap and had system flushed and it has not helped at all. Did you find a solution? if so could you fill me in and help me out, I don't know what else to try... living in Wisconsin with no heat isn't. fun! any help would be greatly appreciated. my email is cwatts0721@gmail.com
thank you,
Charles
cwatts0721 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
