Go Back   Ford Expedition Forum > Ford Expedition Forum > General Discussion
Sponsored Ads
Register to remove these ads.
General Discussion
Crazy Expedition?!?!
This is a discussion on Crazy Expedition?!?! within the General Discussion forums, part of the Ford Expedition Forum category!
Register to remove these ads. It's free! We have owned our 99 EB Expedition since new... it now has 99,400 ...
Reply
Old 12-24-2003, 03:52 PM   #1 (permalink)
Registered User
Default Crazy Expedition?!?!
We have owned our 99 EB Expedition since new... it now has 99,400 miles. Well.... it has started to go CRAZY!
Last weekend my wife called me from church... it would crank but not start..... by the time I got there.... she had started and was running?? Hasn't done that since.
Then I noticed... when we start the Expy...... all the gauges will "flash" from the bottom position to their top position... then the odometer goes blank.... then everything comes back on...... it has been doing this for about a week... but no other issues.
Today... my wife came back from the grocery store... I got in the Expy to go to my office...... the door ajar light (and the interior lights) would not go off... I checked all the doors and hatches.. all closed..... then the light went off. Went to the office.... got back in.. same thing.... then after about 45 seconds they went off??
No rhyme or reason........ right now all the interior lights are on.. the running board lights are on...... as if a door is open........ I can't get them to turn off.........
What could be causing these problems? Seems like a bunch of problems just popped up. I am concerned I may have to sell the Expy if I cannot trust it.... as my wife and son drive in it everyday???
Any advice you all can provide would be appreciated.
Lance
__________________
1999 Eddie Bauer
1996 Viper RT/10
1969 Mach I
1977 Harley FLH-1200
malcoll is offline   Reply With Quote
Old 12-24-2003, 04:06 PM   #2 (permalink)
Registered User
Default
Follow up.... I just went back outside.... the interior lights were off.... so I opened the passenger side front door...... lights came on... closed door.... lights went off. Opened each door and closed each door... lights went on and off properly.....
Except the drivers door... I opened that door last... closed it.. and the lights stayed on???
Where is the switch for that door? Are all the doors wired to one switch?????
I just looked outside after about two minutes..... the lights are off??
Tried my test again...... lights seem to turn on and off properly till I open and close the drivers door?
I even got inside.... waited... after about 30 seconds the lights clicked off... I operated the ignition.... no door ajar lights.... I opened and closed each door (from inside).. the door ajar light (and interior lights) came on and off properly... then I opened and closed the driver door..... door adjar light stayed on and the interior lights stayed on..... I switched the engine off and (without the drivers door open) left the key in the ignition and there was that "beep, beep" to remind me the key was in the ignition??
So where do I find the switch for the drivers door... it seems to be the problem surfaces when I open and close the drivers door.
Thanks again,
Happy Holidays,
Lance
__________________
1999 Eddie Bauer
1996 Viper RT/10
1969 Mach I
Old 12-24-2003, 06:03 PM   #3 (permalink)
Default
Two unrelated issues seem to be present at this time:
1. The guage sweep is a classic expedition symptom of a dying battery.
2. The light switch triggered by the driver's door is apparently sticking, another commonplace Expedition problem. The switch is part of the door latch housing found in the door. Give the latch and adjacent switch a few shots of WD-40, and close the doors a few times.
__________________
1999 XLT 4x4 4.6
PaulC is offline   Reply With Quote
Old 12-25-2003, 08:38 PM   #4 (permalink)
Guest
Posts: n/a
Default
The deal with the not starting is probably just your Idle Speed Control. It runs about 56 dollars from Napa and just bolts on and plugs in on the top of the motor, installs easily. Was the truck just turning over but not cranking. It will happen again if it is the ISC, the only way to fix is just replacing it. Hope this helps. All of your stuff just seems to be normal wear items. They are all just coming at once.
Old 12-26-2003, 02:25 AM   #5 (permalink)
Guest
Posts: n/a
Default
I had similar and weird light problems with my 98 XLT a few months back and took to Ford dealer and they put in a new battery and all my problems were solved. Hey Auto Zone will do a free OBD II scan to see if there is any codes since someone is pointing to the ISC. I would lean toward the battery!
Old 12-26-2003, 10:53 PM   #6 (permalink)
Registered User
Default
Took battery to AutoZone today for a test... t'was a bad battery.......
Replaced with a new one.... the guage "sweep" went away immediately.... we'll see if the other "symptoms" are gone?
Thankyou for the suggestions,
Lance
Old 01-04-2004, 11:01 PM   #7 (permalink)
Registered User
Default
All symptoms seem to be gone... except the "door ajar" light staying on intermittently.
I did the WD-40 spray down...... we'll see if that corrects that symptom.
__________________
1999 Eddie Bauer
1996 Viper RT/10
1969 Mach I
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
