Go Back   Ford Expedition Forum > Ford Expedition Forum > General Discussion
Register to remove these ads.
General Discussion
PCV hose attachment location?
This is a discussion on PCV hose attachment location? within the General Discussion forums, part of the Ford Expedition Forum category!
Dumb question... 1997 Exp with 5.4... where does the PCV hose connect to. Long story. Thanks, Nick...
Reply
Old 06-28-2006, 12:42 PM   #1 (permalink)
Registered User
Default PCV hose attachment location?
Dumb question...
Thanks,
Nick
archer59 is offline   Reply With Quote
Old 06-29-2006, 10:00 AM   #2 (permalink)
Registered User
Default Re: PCV hose attachment location?
Originally posted by archer59
Dumb question...
Thanks,
Nick
Is the attachment location a secret???
Old 07-02-2006, 01:09 AM   #3 (permalink)
green03's Avatar
Default
It attaches to a manifold vacuum source
Matt
__________________
Matt Robinson
Green 03 XLT 5.4 4x4
Powerdyne Supercharger 9lb (kit homemade) (intercooler coming soon)
Built 4R70W With Alto Red Eagle Clutches and Kolene Steels
Baumann Shift Kit
PI Stallion 10.5" Converter With Triple Disc Lockup Clutch
Magnaflow Muffler/Twister Resonator 3" Pipe
Equal-Length Y Pipe and High Flow Cats
NGK Iridium TR6IX Plugs and Granetelli zero ohm boots.
Custom Sniper Tune by Matt Robinson
Factory F150 18" Wheels
green03 is offline   Reply With Quote
Old 07-11-2006, 02:49 AM   #4 (permalink)
Registered User
Default
I am having difficulty finding the location to the valve. I thought that it should be on the driver side valve cover, but that outlet is permanently attached.
My fear is that the previous owner jb welded a plastic coupling in place of the pcv.
I am getting codes for lean banks and having weak acceleration up hills occasionally.
Does anyone have a picture of the place where the valve goes and a description of how to replace the valve?
HI Expedition is offline   Reply With Quote
Old 07-11-2006, 03:39 PM   #5 (permalink)
green03's Avatar
Default
One side (valve cover) has a PCV valve and goes to a manifold vacuum source and is a smaller hose. The oposite side valve cover is the vent side and it should have a larger hose that hooks up between the mass air meter and throttle body.
If you are getting a lean bank code the vent side is probably disconnected somehow and allowing unmetered air to enter the system between the mass air meter and the throttle body.
Take a picture of the suspicious location for us if you can.
Matt
__________________
Matt Robinson
Baumann Shift Kit
Old 07-12-2006, 06:11 PM   #6 (permalink)
Registered User
Default
I solved it. I was looking at the vent tube thinking that it was where the pcv was supposed to go because the other hole in the valve cover (passenger side) had a plug in it. After researching, I found out that the pcv was supposed to be on the passenger side. So I searched farther back on the cover for the pcv, and I found that it was not hooked up. It was hiding in some hoses. The previous owner must have lost it and replaced it with a plug.
Now, I need to erase the codes and see if that was it. There are four codes, but I think this could have been responsible for all of them.
Thanks for the response.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
