Problems with Rotor removal
vamuso
Tampa
I'm having issues removing my rear rotors. I have read that F-150's and the original model Expeditions have had issues with the rotors rusting to the hub.
So here are the details. I have a 2003, 2WD, with 38k miles. The rear brakes have never been changed and the vehicle is 3.5 years old. I live in Florida just a few blocks from the water. I have tried some penetrating oil and can't get them to budge. The calipers and caliper bracket is off. The parking brake is also off. I don't think there should be anything else that should be holding them in.
So has anyone else had issues?
mustangrfast88
middletown oh
never messed with the backs on mine yet but when i did change the fronts it took me 3 hours of just beating on it with hammers and spraying pb blaster on it and they finally just come off
JoeExpedition
Western Mass
I had borrowed a friends Snap-On puller. The autoparts stores typically carry only small pullers and they tend to be junky.
lakmflx
P.C.B
You heard right... The rotors on these things need alot of pounding to get them off. You might want to buy some penetrating oil to help things go alot quicker while you are beating it with a hammer.
Patrick
Tennessee
joeExpedition has the right idea. get a puller big enough and it will pop off alot easier than beating it with a hammer. worked for me. turned out my emergency brakes very bad shape, on both sides
max357
