Go Back   Ford Expedition Forum > Ford Expedition Forum > General Discussion
Register to remove these ads.
General Discussion
Sticky worthy??? Quick fix for rear wiper motor turning but not moving wiper arm
This is a discussion on Sticky worthy??? Quick fix for rear wiper motor turning but not moving wiper arm within the General Discussion forums, part of the Ford Expedition Forum category!
Does your rear wiper motor make a clicking sound but the wiper arm doesn't move? It may not be the ...
Like Tree2Likes
Reply
Old 08-24-2011, 09:28 PM   #1 (permalink)
Registered User
Exclamation Sticky worthy??? Quick fix for rear wiper motor turning but not moving wiper arm
Does your rear wiper motor make a clicking sound but the wiper arm doesn't move? It may not be the wiper motor broken again but something simpler and free to fix in less than 10 minutes. When my third rear wiper motor in a month stopped moving the wiper arm I investigated further. Turns out its not a bad motor or worn gears. The cause is wiper arm assembly spring. The spring coils are too strong and knock the pivot screw out of alignment with the internal gear drive. Take note of how your rear wiper motor is working by listening for the click which should be the wiper arm rotating on the windshield. If your wiper arm doesn't move then remove the wiper arm and watch the pivot screw. If it turns then this fix is for you!!!
Here is the fix - You will need a flat head screw driver and a 1/2" wrench, that's it!
1. Remove rear wiper arm assembly, remove plastic cover from base and loosen & remove nut. Then pull off rear wiper arm assembly, you may need to pull with some force! See pic #1 & #2
2. Turn over the wiper arm assembly. Backside facing you. Next, pry open / expand wiper arm spring (bend wiper arm back which stretches the spring)
See pic #3
3. Place flat head tip of screw driver into the first spring closest to wiper.
4. Release spring, trapping tip
5. Twist flat head tip which create an opening (about 1/8") between the spring loops.
See Pic #4.
6. Spring wil look like bubbled (See pic #5) after you enlarge a few of the spring coils.
7. Repeat from step 3 with the second spring and so on until you feel you created less tension and a flatter appearance from the base of the arm to the tip of the wiper blade.
8. Reinstall and test....you should see difference in how freely it moves.
9. Yes, this proceedure applies less pressure to the glass but it still cleans the water off of it properly.
Maybe if the mods agree this can be a sticky for those who think its a wiper motor failure but really is too much tension from the wiper arm spring.
Let me know how you make out fellas! It worked for me!
Its been a few days now and my rear wiper always rotates when I turn it on...at least 50 tries so far!!!
273HYPO
fourty03 likes this.
273hypo is offline   Reply With Quote
Old 10-28-2011, 06:37 AM   #2 (permalink)
aircargoo's Avatar
Default
i never ever use that wiper in rear. wish it wasnt there....would look cleaner back there. car wash never get it right to around it when washed.....lol
__________________
1997 expedition 4.6 xlt 4wd
aircargoo is offline   Reply With Quote
Old 10-28-2011, 07:20 AM   #3 (permalink)
dcarr's Avatar
Default
i hate the mark the rear wiper leaves on your window. took my arm off completely
dcarr is offline   Reply With Quote
Old 02-12-2012, 05:55 PM   #4 (permalink)
Registered User
Default
fix worked perfectly for me, thanks!
Frank is offline   Reply With Quote
Old 02-12-2012, 06:51 PM   #5 (permalink)
Default
Good to know for the future. :D Mine works fine. :D AIRCARGO: I wash mine myself so I don't have that problem. LOL :D
__________________
2007 Expedition EL E.B. "Money Pit"
Knautical2001 is offline   Reply With Quote
Old 02-13-2012, 10:12 AM   #6 (permalink)
10K-Watts's Avatar
Super Moderator
Default
i've never used it...in 7.5 yrs...nor on my 4runner that i had...
__________________
04 EB/26" Gianelle Mallorca's/Lexani 305-30-26 tires/5&15% tint/35% windshield+visor/billet UPR-LWR grille/IPCW LED Black Tails/SICK HID's Retro 6K head&fog HIDs/Flowmaster Exhaust/K&N Intake/Power Stop drilled&slotted rotor kit/Superchips Vortex 1950/Pioneer AVIC-D3 Nav/DVD/BT/Boss 15" w/DVD player/12" headrest/2-18" PSI Audio/8 Massive Audio 6.5/3 Nx4 amps/4 Skar Audio 8"/2 Skar Audio 4500.1 amps/Patriot Decals/PTM hitch cover/Eibach Anti-Sway Bar/2" Ground Force drop springs/Suncore conversion
BKA...FREEWAY...AKA...BHSoulja
HOLY ROLLERZ CHRISTIAN CAR CLUB (HRC3) National Member
10K-Watts is offline   Reply With Quote
Old 03-12-2012, 07:59 AM   #7 (permalink)
frito-bandito's Avatar
Registered User
Default
My problem was that the nut that held the arm on was loose, a couple seconds and a pair of channel locks remedied mine.
__________________
1998 Expedition XLT 4X4, 5.4L, 246K miles
1998 GMC C1500 ECSB, 5.0L, 214K miles
frito-bandito is offline   Reply With Quote
Old 02-18-2013, 11:18 PM   #8 (permalink)
Big Red Monster's Avatar
Default
i think we all can agree shaveing that damn thing off our tailgate looks better. im gonna do that on mine eventually
__________________
2002 Ford Expedition Eddie Bauer
Big Red Monster is offline   Reply With Quote
Old 04-10-2013, 12:53 AM   #9 (permalink)
TactialMonkey's Avatar
Default
I just took mine out and put a VW logo over the hole I mean the expedition is really just a monster wagon
__________________
TactialMonkey is offline   Reply With Quote
Old 09-25-2013, 02:17 PM   #10 (permalink)
Registered User
Default
This is an old thread, but I have to say this helped me fix my rear wiper. I didn't have to adjust the spring, just remove and reinstall. On mine, the nut was too loose, and that prevented the motor from operating the wiper. Once reinstalled, everything worked as expected.
piano_71 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
