Where do i put freon in my 2001 Expdition
!keithnra
Jacksonville FL
I have a 2001 expy with the eddie bauer edition and the 5.4 Triton. I need to know where t put some freon in the AC system, i think it is a little low on freon and and i cant figure out where to put some in at.
ELVATO
Orlando, FL
Should be something like that. This is where it is at in an 03+ Expy:
I forget who said it was elsewhere on the older ones. But, it should still be on the passenger side of the engine, probably with a black cap. You will probably find two caps. The refill kit should only fit the low side. Follow the instructions on the can.
Also, if you have rear A/C, make sure you have both the front and rear A/Cs set to max when refilling it.
walnuts4x4
Watertown, NY
on passenger side of firewall under a plastic cover with 2 wire harnesses, behind side of battery..... look up under all that for a silver cylinder and on it is the low port side for A/C follow lines to it... hard to see it the first time...
K
!keithnra
Jacksonville FL
thats what i got. I found it today, i had to take the cover off the firewall to finally see it but i got some 134A in it and it is much better.
jywu
Yorba LInda
hi guys, new to the forum. I'm trying to refill the r134a as well but can't locate the low side port. I believe I'm looking in the right area but still can't specifically see the valve stem. Could someone point me in the right direction?
JonnyBlaze
NH
I just recharged my ac a couple of days ago. Took 7 12oz cans to finally get cold. Thats $12.49 a can.
Racenut
Deming, New Mexico
If you look at both of your pics, it wll be under that black metal braket that is mounted to the firewall holding wire harnesses. There are two I belive 8mm bolts that hold that bracket to the firewall and once you get that off you will be able to see it on the side of the reciver, just follow that metal line, take off the bracket and gently move it to the side, and it will be towards the motor side of the silver canister that is hidden by the bracket. ( if you look really close in the pics you can see the reciver[silver canister])
jywu
Yorba LInda
okay sounds good. I'll be sure to take a picture of the actual port for future reference. Thanks for the help. Why in the world would Ford put it in such an inaccessible area?
geovanni
