Go Back   Ford Expedition Forum > Ford Expedition Forum > 3rd Gen - 2007 - present
Register to remove these ads.
07-12 Intake mod - Like Gotts mod but easier & cheaper
This is a discussion on 07-12 Intake mod - Like Gotts mod but easier & cheaper within the 3rd Gen - 2007 - present forums, part of the Ford Expedition Forum category!
Dunno if this is old news at this point or not, if so just ignore me I found that the ...
Like Tree6Likes
Reply
Old 12-05-2012, 08:34 PM   #1 (permalink)
jasonlmarsh's Avatar
Default 07-12 Intake mod - Like Gotts mod but easier & cheaper
I found that the snorkel on the airbox has approximately 2" inner diameter, and seems really restrictive to me. So I replaced the snorkel with another Ford Snorkel with approximately 3.25" inner diameter. It was a direct swap, 15 minute job, and best of all.... Cost less than $5
Here's the old airbox snorkel next to the new one
After you pop out the old snorkel using a screwdriver and a little brute force, you have this
Pop in the new snorkel with a little more brute force
Ford P/N 7C3Z-9F721-A cost $4.58 + tax at my local dealer
In my opinion, this setup combined with a high flow drop in filter will flow as much as any $200+ CAI on the market. There's really no restriction between the airbox and engine, being that it's all 3.5" although I imagine the airflow is really turbulent, so that's my next mod on the list. Parts ordered, so hopefully next week I'll be posting my $75 Polished intake on a budget build.
__________________
2007 Expedition EL Limited 4x4
22" Ford rims, Cooper Zeon LTZ tires
Edge EVO-HT Programmer
Pioneer AVIC-Z130BT
Mini H1 Projector Retrofit w/LED DRL's
HID's - 5000k 55w Heads & 3000K 35w Fogs
LED Tails & High Mount w/ VHT Nightshades
Street Scene Black Powdercoated Grille Inserts
5% Tint all around
jasonlmarsh is offline   Reply With Quote
Old 12-05-2012, 10:06 PM   #2 (permalink)
Default
Humm interesting. Props for finding a ford part number that worked. Mind me asking how you managed to find it?
Anyways, I haven't looked at the CAI kits out for the truck yet, since I just got it back in late September, but do any of them try to redirect air to the box? As of right now, this cone that you modified with a larger one sits in the fender, which from what I saw while doing the brakes the other day didn't have any free flowing air piped to.
Now if you run a hose from that tube to the front somewhere, I would think that would help out a bit more.
CJ0920 is offline   Reply With Quote
Old 12-05-2012, 10:11 PM   #3 (permalink)
Default
Have you driven it yet to see if throttle response is better. I am tuned but have not done an intake yet. I know members on here say they are ineffective - but it made a difference on my F150. Interested to hear some results. Thanks, Mike
__________________
2013 F150 FX2 5.0 Screw, 401a, 3.55 ELD - that is all
Wife's ride 2011 Expy XLT with 202 package
Previous Fords: 2006 Expy EB 4x4, 2003 F150 Screw, 1987 Ranger 4x4
other rides: 1986 Samurai 4x4, 1987 Toyota p/u 4x4 22r, 1989 Toyota 4-runner 4x4 V6 5sp, 19987 Ranger 4x4, 1991 Isuzu Rodeo 4x4 5 speed, 1993 Toyota x-cab 4x4 V6, 1995 Jeep Grand straight 6,1998 Jeep Grand straight 6, 2001 Jeep Grand 4.7 V8 --> begin the Ford rides.
mtondreo is offline   Reply With Quote
Old 12-06-2012, 10:17 AM   #4 (permalink)
Default
It's hard for me to compare because I've been driving with no snorkel at all for the last month. The throttle response is noticeably better, but I'm used to it already, from having removed the old snorkel a few weeks back. Also there is a little more engine noise when your foot is heavy on the pedal (which I like), but under light throttle you can't tell a difference. There is less engine noise than having the snorkel completely removed. What I didn't like about having no snorkel was there were occasionally "burps" or whooshes of air (for lack of a better term) that sounded nasty. I have not heard those noises at all since putting this bigger snorkel on. I think HP gains are minimal, maybe 1~2 hp if anything at all, although I could see it helping on MPG since the engine is not having to work as hard to get the same amount of air into it.
I was doing a lot of research and found somewhere that someone said they thought late model F250 gas trucks had the same airbox with a bigger snorkel. So I got my hands on an F250 and confirmed that, then bought the part. Even if it didn't work, I would have only been out $5 so not a big risk. I was worried at first because it looks like the shape was different when holding it up to the old snorkel, but once I got the airbox out, that snorkel slid right in with no issues at all.
On the ram air ducting, I'm conflicted on that... this is my opinion, so take with a grain of salt. I've never been a fan of ducted ram air setups that pull air from down close to the ground, although I'm a big fan of direct ram air that is coming in through a scoop in the hood. In terms of the ducted ram air setup, my opinion is that it's not getting any cooler air than what is inside your fender area, so the only real benefit I see is pressurizing the airbox. But they are more prone to pick up trash, rocks, dirt, etc, and god forbid you hit some deep water... And finally, unless you're moving forward all of the time, there's no pressure in that tube. So from a stop, your engine has to suck air up that long tube until you are moving forward fast enough to pressurize the tube. In a lot of stop and go traffic, I see that as a HP & MPG killer.
__________________
Pioneer AVIC-Z130BT
5% Tint all around
Old 12-06-2012, 11:54 AM   #5 (permalink)
01yellerCobra's Avatar
Default
Good info. I popped the air filter out the other day to check it and did a quick look to see what I could change. I've thought about opening the bottom up with a dremel and using a drop in filter. But Summit has Spectre kits for $150 right now. And it's chrome. Decisions, decisions.
01yellerCobra is offline   Reply With Quote
Old 12-06-2012, 12:15 PM   #6 (permalink)
Default
The intake I'm working on should be around $75 (not including the filter, I'm just running an STP paper filter for now), and it retains the stock airbox. I should have pics and info up by Tuesday/Wednesday of next week if you are interested.
__________________
Pioneer AVIC-Z130BT
5% Tint all around
Old 12-06-2012, 12:55 PM   #7 (permalink)
Default
I'm always interested in people's projects. At the very least it's cool to see what other people are doing. I might just end up going with a CAI because it gets rid of the air box altogether. I would be interested if you have any difference in mileage with your mods though. I imagine all the silencers on the intake tube can't be good for smooth air flow.
Now that I think about it I might grab that snorkle. There's a dealership right down the street from my work. It would be interesting to if it makes any difference going to Disneyland tomorrow.
__________________
2015 F250 with 6.7L
2008 Expedition EL XLT- RIP
Old 12-06-2012, 03:11 PM   #8 (permalink)
Default
Good luck with them having it in stock. My dealer had to order it for me.
__________________
Pioneer AVIC-Z130BT
5% Tint all around
Old 12-06-2012, 03:54 PM   #9 (permalink)
Default
Too bad I just missed your post. I just got back and they didn't have them in stock.
Old 12-06-2012, 06:27 PM   #10 (permalink)
timberwoof's Avatar
Default
Good info
__________________
2006 Expedition XLS, AEM Brute Force Intake
timberwoof is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
