2008 Battery Drain?
poppadon56
Ottawa,Ontario
I have an 08 - Limited EL and the battery has been giving me issues for a couple of years. I have brought it to my Ford dealership at least 4 times and they can't find any problem. According to my dealership they have disconnected the rear wiper and the power running boards because they weren't working properly or not working at all. The problem of the battery draining still exists. I have also replaced the battery twice to no avail. The latest was on Monday, I started the truck up with no problems, drove a couple of miles to the store and when I came out it didn't start. Got a boost and have been Ok since.
To my question, is .03-.04 amps a normal drain for this vehicle when I think everything is off? I would have thought my many trips to service would have discovered something.
Thanks,
Don
stamp11127
Temple, Georgia
Normal current draw once all the electronics are "off" should be 30-50 mA. One mA = .001A
In order to start troubleshooting we need to know the battery voltage at different times. Readings should be taken with a multimeter.
1) Prior to starting - gives us a starting point
2) Engine running - gives us charging voltage
3) When it doesn't start after it has been running - gives us the battery state of charge at this point.
P
poppadon56
Ottawa,Ontario
2008 - Battery Drain
Here's voltage for 1 & 2. I'll report back on 3) when it fails to start.
1) Prior to starting - 12.11
2) Engine running - 14.49
I may attempt tomorrow to perform a test for battery drain.
stamp11127
Temple, Georgia
Battery voltage & % of charge:
12.6 = 100%
12.4 = 75%
12.2 = 50%
12.0 = 25%
11.8 = 0%
You may have a battery issue, the car wasn't running long enough to fully charge the battery or there is a problem in the harness.
The charging voltage is within spec.
Any electrical testing should be done with a fully charged battery, if possible.
P
poppadon56
Ottawa,Ontario
Charged battery
1) Prior to starting - 12.62
Waiting for truck to not start and will take voltage then.
