kindly update your signature line with year model and engine information. This can be done in the USER CP section as this information helps others give you replies specific to your expy
None ot matters to his question though - the sway bar is a sway bar. I'd bet dollars to donuts all 2014s have the same.
To the OP - What does 'upgrade' it mean? Are you hoping to reduce body roll?
Actually I did give the required info in my post. If I have a question that's what I do. I just don't like clutter or signature's for that matter.
I hope that address's your concerns.
I'm guessing it's shocks or worn springs. Check the alignment, maybe?
You are correct in that you gave the information in your post And if you don't see or understand the purpose behind the signature line then I'll apologize for wasting your time
The shocks I pulled off the front of mine looked fine until I got them off the truck. Then I could see the blown seals.Alignment was checked, was fine. It has under 15K on it, shocks look good no oil showing. But that doesn't mean much. So, a set of shocks and a couple of bar's might do the trick.
