2010 Ford Expedition XLT Temperature Blend Door Actuator
I'm sure this is no hep to you, since your post is from February, but the blend door actuator repair was easy.
Pop out radi bezel, radio, and it's right there. rear bolt is tough to get to, had to use an 8mm socket and a pair of needle nosed pliers to turn it, no room for the socket wrench, but once that was done, the motor popped right out, and within 15 minutes, the new one was in, radio and radio bezel back in, and worked perfectly.
I asked for Ford dealer what they would charge to install it, didn’t know it would be this easy before I tore it apart…they wanted $6-700 to do the repair. Are you kidding me?? $6-700 for a repair that took a couple garage monkeys an hour while drinking Land Sharks??? Cmon Ford, you can do better than that!!
