HoustonTexan
Is there a way to program the mirrors to fold in when locking the vehicle and fold out when unlocking? I have searched and keep coming up empty. Thanks! Sorry, it is a 2014 Expedition Limited.
Memory Mirrors (If Equipped)
You can save and recall the mirror positions through the memory
function. See Memory function in the Seats chapter.
That statement has zero to do with his question.
The answer to the question is no, you can only power fold via the mirror switch, this is a Ford not a Benz or Infiniti. You can get them to fold via an aftermarket alarm if you are really that interested. As you will learn these trucks are huge technology turds is about every aspect. I just had a 2015 as a loaner and worse than the ecoboost was it's lack of technology still, no lane keeping, no distronic cruise control, no cross traffic detect with autobrake no park assist, no hydraulic body control, the list goes on.
I was going to create a new thread but thought I would update this one instead. I believe there may be a way to do this for 2015-17 vehicles. After studying the wiring diagrams, it may be possible to tap into the driver door lock motor wire (Blue-Green) near connector C465 (pin 36) at the LH "C" pillar. By running a wire from here, through a diode, and connecting to the Grey-Brown wire coming from connector C311 (pin 2) under the driver's seat, it would provide a remote input to the Driver's Door Module (DDM) to fold/unfold the power mirrors.
If I'm reading the diagrams correctly, whenever you use the keypad or the remote to lock the doors, a 12V pulse will appear on the Blue-Green wire at connector C465, pin 36. The same thing will happen if you enter the code on the keypad or use the remote to unlock the doors, but current will be flowing in the opposite direction. Either way, tapping this wire will provide a brief 12V pulse during remote lock and unlock. Connecting this pulse to the power fold input on the DDM (via an isolating diode) should cause the mirrors to fold/unfold automatically during remote lock/unlock.
