Hi guys, new to the forums!
I have an 08 expy. I started getting the wrench light with no symptoms about a month ago. 2 weeks of no symptoms went by and I started to ignore the light. My code reader couldn't pull a code and the CEL was not on.
Soon I would drive for a bit, shut down, then get a no crank no start. OR a partial crank no start. Let it sit for a bit, checked the fluids, still no CEL. Try to start it and I would crank over no problem, but I would have the wrench no CEL.
Replaced the starter as I thought it was the solenoid. Didnt get the wrench or starting problems for 3 solid joy filled weeks. Until I took a long trip. Today I did a 60 mile run cruising at 85 most of the way. shut her down, and I got a no crank no start. Let it sit for 10 min, cranked over fine. Got a wrench light. Made the same trip home, same speed, with a wrench light the whole way home. Got home, shut down, start up fine no light.
Now to what I have done in the recent past. New plugs, new VCT solenoid driver side, dropped trans pan, changed fluid and filter, had the PCM/ TCM updated. The ford laptop didnt pull any codes.
Summary: NO CEL, Intermittent wrench light, intermittent no crank/ partial crank no start
HEELLLPPP I have considered that I got a bad remand starter. But it seems the problem is so intermittent that the starter may have never been the problem to begin with. just a $140 coincidence.
