Go Back   Ford Expedition Forum > Ford Expedition Forum > 2nd Gen - 2003 - 2006
Register to remove these ads.
03 no crank...no clicking
This is a discussion on 03 no crank...no clicking within the 2nd Gen - 2003 - 2006 forums, part of the Ford Expedition Forum category!
Just drove it an shut it off for 20 mins...won't crank....everything lights up but no start...no clicks nothing.... help?...
Like Tree1Likes
Reply
Old 12-08-2013, 07:49 PM   #1 (permalink)
Registered User
Default 03 no crank...no clicking
jshreve is offline   Reply With Quote
Old 12-08-2013, 08:48 PM   #2 (permalink)
Default
Check the terminals and make sure they are tight.
Copper93 is offline   Reply With Quote
Old 12-08-2013, 10:44 PM   #3 (permalink)
metaldrgn's Avatar
Default
Is the security light blinking with the key in the run position?
Check for power at the F1.101 fuse and make sure the fuse is good.
Put it in neutral and try and start it. It could be your park/neutral switch. If that doesn't work pull your starter relay and check pin 86 to the negative battery terminal (or any ground) and verify 12v+ to make sure that part of the circuit is good. If that's good you could try swapping a like relay and seeing if it starts. If not check pin 85 to the positive terminal and have someone turn the key to the start position (try to start the car even though it won't because the relay is out) and check for 12v+. If you don't get the 12v+ something is preventing your PCM from closing the internal relay (i.e. a bad PCM or security system isn't cooperating).
__________________
2001 Yukon XL 4x4
2001 Grand Cherokee Ltd. 4x4
2002 Tahoe Z71 4x4 Flexfuel
2003 Expedition XLT 4x4
2006 Durango Ltd. 4x4
metaldrgn is offline   Reply With Quote
Old 12-09-2013, 07:45 PM   #4 (permalink)
Registered User
Default
Well I left it sit for about 2 hours an it started right up..haven't had a problem with it since
Old 12-09-2013, 10:58 PM   #5 (permalink)
metaldrgn's Avatar
Default
I'm glad it worked but I can only imagine you will be weary of it happening again. Could just be the key or lock cylinder not reading the key right. when it wouldn't start, did the security light flash on the instrument panel? If you have more than one key and this happens again, try the other one.
__________________
2001 Yukon XL 4x4
Old 12-10-2013, 08:40 PM   #6 (permalink)
Registered User
Default
Did it again ..security. light does not flash ...I can also hear the relay click on the passenger side fuse panel....any ideas ...I rolled it forward an put it back n park and still no start even in neutral
Old 12-10-2013, 09:20 PM   #7 (permalink)
Registered User
Default
Security Light stays solid for about 4-5 sec then goes off...any ideae
Old 12-10-2013, 10:30 PM   #8 (permalink)
ExpeditionAndy's Avatar
Default
Lets start with the basics. What year is your truck?
In the mean time I remember reading something about this somewhere, let me do some research.
__________________
Andy,
05 Eddie Bauer Expedition Blue/Gold 4WD
20" King Ranch Wheels 275/60/R20 Cooper Zeon LTZ Tires
Dual Auto Temp Controlled System w/ H & C Seats w/ Rear Aux A/C-Htr Controls
HD Tow Package - Heated Mirrors w/ Signal Indicators & Puddle Lamps
Adj Foot Pedals - Memory Pwr Front Seats - Pwr 3rd Row Seats
Audiophile/Premium Sat Compatible AM/FM Stereo In-Dash 6 CD/MP3 Radio
Reverse Sensing System - AdvanceTrak with RCS - TPMS - Air Suspension - Safety Canopy
ExpeditionAndy is offline   Reply With Quote
Old 12-10-2013, 10:44 PM   #9 (permalink)
Registered User
Default
2003
Old 12-10-2013, 10:47 PM   #10 (permalink)
Default
Thanks, sorry I didn't see in the title - Duh!
__________________
Andy,
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
