Go Back   Ford Expedition Forum > Ford Expedition Forum > 2nd Gen - 2003 - 2006
Register to remove these ads.
A4WD vs. 4WH ?
This is a discussion on A4WD vs. 4WH ? within the 2nd Gen - 2003 - 2006 forums, part of the Ford Expedition Forum category!
Can anyone tell me the difference between A4WD and 4WH? When to use one over the other? Thanks, Chris...
Like Tree3Likes
Reply
Old 12-06-2011, 07:03 PM   #1 (permalink)
Registered User
Default A4WD vs. 4WH ?
Thanks,
Chris
hlygrail is offline   Reply With Quote
Old 12-06-2011, 07:14 PM   #2 (permalink)
IAExpy's Avatar
Default
I belive A4WD (automatic 4 wheel drive) is when your truck is in rear wheel drive mode, but will automatically flip into 4WD if the rear wheels start to slip (like on an icy road, or in my case going through mud deeper than i expected) whereas 4WH is just your regular 4WD with normal gearing, as opposed to lower gearing (less confident about that answer)
someone else may be able to provide a more detailed answer
IAExpy is offline   Reply With Quote
Old 12-06-2011, 07:16 PM   #3 (permalink)
sgtowing's Avatar
Super Mod, Supporting Members
Default
That about sums it up.
__________________
2005 Expedition Eddie Bauer 4x4
Volant Cold Air Intake, Borla Exhaust. 18" 2010 F150 King Ranch Wheels
sgtowing is offline   Reply With Quote
Old 12-06-2011, 07:18 PM   #4 (permalink)
panda24619's Avatar
Default
4wd is a pain in the but to turn with on the street. front tires want to go the same speed as the rear tires. A4wd is what IAE has already said. it switches on when it senses rear wheel slip. ford designed it to be used during the rain.
__________________
1998 XLT 5.4 4x4
DEAD!!!!
http://www.lalalalalalalalalalalalalalalalalala.com/
panda24619 is offline   Reply With Quote
Old 12-06-2011, 07:25 PM   #5 (permalink)
DF5.4's Avatar
Default
A4WD engages the transfer case and engages the front axles when slip is detected. 4WH is full 4WD. Don't use it on dry pavement. It will wear/break something in the drivetrain.
__________________
2007 XLT, 4x4, 5.4
Superchips Cortex
K&N CAI
Gibson Swept Side
DF5.4 is offline   Reply With Quote
Old 12-06-2011, 08:23 PM   #6 (permalink)
Registered User
Default
You guys are great!
It sounds like A4WD is pretty smart, but I understand I shouldn't keep it engaged unless driving during poor weather conditions, right?
Old 12-06-2011, 08:37 PM   #7 (permalink)
DF5.4's Avatar
Default
Originally Posted by hlygrail View Post
You guys are great!
You can run anytime with A4WD. The only thing is you are still turning the transfer case and front drive shaft all the time. 4WDHigh you should not use all the time.
__________________
2007 XLT, 4x4, 5.4
Superchips Cortex
K&N CAI
Gibson Swept Side
Old 12-07-2011, 01:34 AM   #8 (permalink)
mindgame's Avatar
Default
Is this correct? (Assuming that you place the Expy on all 4 jack stands, for diagnostics)
2H - Hubs disengaged, BUT transfer case still spins. Another words, front wheels will not spin, when though the half-shafts are spinning.
4AWD - Hubs disengaged, but if ABS sensor detects speed difference, IWE solenoid is disengaged to prevent vacuum from going to the hub actuators. Thus all 4 wheels end up spinning.
4H - All wheels ar espinning.
4L - All wheels spinning...
Just asking.. When on the road, when I switch to 4AWD, it sounds and feel like 4H is on instead... Anyone experienced this? I have already repalced the IWE solenoid.. I am thinking I am having ABS/Speed sensor issues...
Thanks1
__________________
2004 XLT 5.4L | Rize 8" Suspension Lift | RadFlo 2.5 Front Coilover with remote | 20 x 9 Fuel Gauge Machined Wheels | Pro Comp Xtreme A/T 35x13.5x20 | Power Slot Cryo Rotors | Troyer Dual efans | Custom Dual Fan Shroud | Borla Muffler | Pure Power Stainless Steel Oil Filter | K&N Series 77 Chrome Intake | Optima Yellow Battery | Custom Front and Rear Double Cardan Drive Shafts
Official member of Lifted Expy and Big Boyz club
mindgame is offline   Reply With Quote
Old 11-10-2012, 09:57 AM   #9 (permalink)
Idahokid's Avatar
Default
I was useing the 4awd last night since we got 6-8 inches of snow.I think it works slick.Sometimes on pavement,then slick ice.The 4awd doesn't jerk going around corners.The 4wd drive is like any other 4wd.4awd runs in 2wd untill the tires slip then goes into 4wd and back to 2wd when tires stop spinning.It was the first time I used it and worked good.
__________________
Don't believe everything you think.
1998 XLT Expedition.
Idahokid is offline   Reply With Quote
Old 01-30-2013, 09:18 PM   #10 (permalink)
Default
In Four High (4H) mode, the center multi-disc differential (inside the transfer case) is locked, locking the front and rear propeller shafts together for a permanently locked front:rear 50:50 torque spilt.
Due to this "locked-up" nature, Four High should NEVER be used on pavement, not even on wet pavement. Torque windup and drivetrain binding will occur, which will shorten the life of the four-wheel drive system. Under prolonged binding, drivetrain failure will occur.
Sometimes people will describe Auto mode as "its like a automatic Four High. Under slip it auto engages Four High", or some similar description.
This is rather incorrect as Auto mode is a bit more complex than that. The front axle, front differential, and front propeller shaft are always engaged in Auto mode, whether they receive torque or not.
Also, torque is sent to the front wheels in 10 percent increments (10, 20, 30, 40, up to 50 percent - 100 percent in newer versions) based on tractive conditions and wheel slip.
The front:rear torque split in Auto mode (for the BorgWarner 4406 transfer case) is variable from 0:100, 10:90, 20:80, 30:70, 40:60, up to 50:50 (lock). As the center multi-disc differential allocates the engine’s torque output, increasing the percentage of torque sent to the front wheels, the percentage of torque sent to the rear wheels is decreased. The torque split is also adjusted or "fine-tuned" if wheel slip lessens or worsens while torque is being transferred.
Auto mode will not keep the 50:50 torque split very long, to guard against torque windup and drivetrain binding while on pavement.
From 2003 to present (BorgWarner 4416 and 4417) the ControlTrac system can send 100 percent of the engine’s torque output to the front wheels – for "temporary front-wheel drive". This capability of putting 100 percent of torque to one axle or the other is called "torque biasing".
The front:rear torque split in Auto mode is variable from 0:100, 10:90, 20:80, 30:70, 40: 60, 50:50, 60:40, 70:40, 80:20, 90:10, up to 100:0.
ControlTrac four-wheel drive is not you’re grandfather’s 4x4 system. It has a computer control system with dedicated microprocessor, and advanced control software that is artificially intelligent.
In Auto mode, it thinks and learns. Its also monitors your driving input and from 2003 onward, it can also predict traction loss before it happens.
Even when you think its driving along sending torque to the rear wheels, it will periodically supply torque to all four wheels. In this respect, its very much a full-time system.
LocDoc is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
