Go Back   Ford Expedition Forum > Ford Expedition Forum > 2nd Gen - 2003 - 2006
Register to remove these ads.
Brakes slow to release?
This is a discussion on Brakes slow to release? within the 2nd Gen - 2003 - 2006 forums, part of the Ford Expedition Forum category!
Anybody ever have any issues with your brakes slow to release if your sitting with them pressed for any extended ...
Like Tree1Likes
  • 1 Post By bubbadabulldawg
Reply
Old 03-11-2013, 05:29 PM   #1 (permalink)
Registered User
Question Brakes slow to release?
Anybody ever have any issues with your brakes slow to release if your sitting with them pressed for any extended period of time? Like at a slow drive through, or an extremely long red light?
If so, any ideas what may cause that?
Thanks
04EB is offline   Reply With Quote
Old 03-11-2013, 06:32 PM   #2 (permalink)
1997SCEBFEX's Avatar
Default
how many miles on your vehicle?
when was the last time your brakes were serviced?
are you talking about the pedal returning to normal position, or the pads releasing from the rotors? does it feel like they're dragging, or are they making 'squeal/squeaking' noises? is it only one-side, front/back, or both.
have you checked your master cylinder fluid level? is the cap loose perhaps.
PanHandler.
1997SCEBFEX is offline   Reply With Quote
Old 03-11-2013, 06:50 PM   #3 (permalink)
Registered User
Default
PanHandler.
There's about 230,000 miles on it. I recently (within last month) changed all the brakes and rotors. Pedal is returning as expected. It does feel like the pads are not releasing all the way after being held for more than a minute or so. It's not making any squeaking noises regularly, just when I start to depress the brake you'll hear a squeak for a second then goes away as I keep the pedal depressed. I can't quite tell if it's just the front that is doing it or front and back both. I don't believe it to be just one side because while it's doing it if I let go of the wheel it doesn't pull to either side. The fluid is at the proper level and the cap seems to be on good and tight.
Thanks
Old 03-11-2013, 06:57 PM   #4 (permalink)
Default
did you grease the slide rails and use the replacement parts that came w/ the pads?
did you use OEM pads?
sure someone else will chime in and it may just be a matter of time until you get some wear on the new rotors.
PanHandler.
Old 03-11-2013, 07:06 PM   #5 (permalink)
Registered User
Default
PanHandler.
Yea I'm sure but I don't really want premature wearing at a rate that is going to destroy the rotor. I use OEM style semi-metallic pads. I greased everything up pretty good with brake grease. It just seems to me that this shouldn't be an issue. I've changed 3 vehicles brakes all within this month and none of the others are having any issues. So it's a bit weird. Thanks again.
Old 03-11-2013, 08:47 PM   #6 (permalink)
ArtGamer60's Avatar
Default
I have seen problems as you describe ? caused by the master cylinder . Food for thought .
__________________
2001 Ford Expedition Eddie Bauer 4x4 w/ 5.4 L Triton V8 / 4R100 Trans
SUPERCHIPS 1100 Flash Module; Blue Spectre High Flow Filter w/ Gott's Mod Eagle Eye headlight upgrade Carbon Style tail lights
ArtGamer60 is offline   Reply With Quote
Old 03-11-2013, 09:12 PM   #7 (permalink)
Registered User
Default
I was wondering that too, but also wondering if it was anything to do with vacuum as well.
Old 03-11-2013, 09:27 PM   #8 (permalink)
ArtGamer60's Avatar
Default
You thinking the Brake Booster ? try squirting a little soapy water around ? should seal up the vacuum leak momentarily ?
__________________
Old 03-12-2013, 11:17 AM   #9 (permalink)
Registered User
Default
Thanks, I'll give that a try this weekend and see if that will help or not.
Old 03-21-2013, 12:16 AM   #10 (permalink)
bubbadabulldawg's Avatar
Default
Take off the calipers, remove and clean the slides, the areas where the pads touch and slide on (silver clips) and now here's the part no-one checks and does REMOVE THE RUBBER SLIDE BOOTS AND CLEAN THE RUST BUILDUP INSIDE THE CALIPERS! Put back together and use the silver anti-seize paste on the sliders and the silver clips. Do this for each wheel and you will happy that you have brakes that work like they should again! You may also want to step up to ceramic pads also for better stopping, it is a very cheap upgrade over the semi-metallic pads for better braking especially when you need to stop 6k in a hurry!
Kermit likes this.
__________________
2003 XLT ( Newer body style)
Laser Red Metallic w/ matching trim
20" MB Motoring V-Drive Chrome Wheels, MICHELIN LTX M/S-2 275/55/20
Chrome Street Scene Main & bumper grills
Pioneer Z2 w/ 13" flip, PS2, XM w/navtraffic, wireless headphones, 12disk cd changer, backup camera, JL Audio 12W3's, JL Audio 300/4 & 500/1
bubbadabulldawg is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
