k_aimone
So I did a full break job about a month ago. When I went to start I noticed the front drivers wheel was tough to turn. Once I removed the wheel I couldn't get the caliper off of the rotor. I figured it was a problem with either the caliper or the hose, so I changed both, did all the pads, four rotors, and a fluid change.
Fast foward to today. I went to have the new tires installed and the same problem. The caliper is still holding some pressure. So much so that there is evidence of overheating on the rotor and caliper. I don't swapping out the parts again, which I will do and a wheel bearing, but I can't think of what is causing the issue. Could it be a master cylinder?
The truck is an 05 2wd.
If you have any ideas please chime in.
Thanks in advance.
Ken
Thanks in advance.
Ken
