Rear Window Washer Not Working
jwt66
Anyone had any issues with the rear window washer not working. 2004 Expedition XLT 4X4. Bought it new. Only 33K miles on the vehicle.
treycool94
vienna VA
do you have wiper fluid? fill it up and see if it works otherwise i would trace the line see if its messed up
J
jwt66
There is only one resivoir..........correct? There isnt one for the rear is there?
ELVATO
Orlando, FL
Yea, the reservoir is for both front and rear. Does the arm operate at all, or only in certain positions? Did it just stop working? Have you checked the fuse(s) to make sure they are good?
Fanatic1074
Nashville
Any idea where it's located?
You have to remove the two rear pillars and the two middle ones and the two or three push pins (whatever they are call) to remove the headliner enough to get to it. Its in between the headliner and the top of the truck at the very back. Its pretty small from what i remember maybe 3 or 4 inches long and maybe an inch in diameter.
