You can salvage the lower arm and just press out/in the old/new bushings, and ball joint. This is the path that I will be taking shortly. Pressing replacement bushings is not the easiest/fastest way to get things done, but it's cheaper overall.
And just an FYI, the second gens do not have a pitman arm.
If you want to do everything, I would suggest:
FRONT SUSPENSION
Upper control arms
Lower control arms
-As an assembly ideally(if your budget allows)
-Or salvage old arm, replace ball joint and have new bushings pressed in. (most shops like it when you remove the old bushing for them, wink wink.)
Sway bar end links
-Check the sway bar bushings too!!
Struts
-Ideally as strut assemblies
-Alternatively, and of course, more time consuming just replace the strut cartridge.
Inner tie rods
-If needed, check for play
Outer tie rods
-I would just do them while I'm in there.
Inspect rack and pinion bushings
-replace if needed.
REAR SUSPENSION
Bushing/Ball joint
P/N 5791016 on Rockauto
Inner tie rod
Outer tie rod
Struts
-Same philosophy as the front on how/what to replace.
I didn't see rack and pinion bushings on Rockauto BTW, but all of these other parts that I reference can be found there.
Good Luck, I'll be doing exactly the things I just laid out here in the next couple months.
