juan214
1999 Expy engine knock..... Back together
So I go on a drive to N.J. from MA. Check all my fluid before I leave. Oil and Filter about 300 miles ago K&N filter with 5W 20. Drove all the way down 250 miles no issues (but the usual valve ping). All gauges reading good getting 10.3 mpg. Cruising between 50 ad 55 mph. Just as I get to my exit I hear something odd. I pull over engine idles rough has a knock. Gauges still fine no CEL.
Damage done I guess, drove off the highway to nearest hotel. Oil level good, filter not collapsed, no leaks, and antifreeze level all good. So I assume a spun bearing. Rented a trunk and trailer ad got it back home. It starts with no issue not even drag on it. Seems to be more of a top end knock than lower. Got a second opinion that person says the same thing as I do. Sound like knock or clatter?
Started disassembling the engine to pull the valve covers to see if the issue is under there. Way to much to get to them so basically started to break it down for a complete pull.
Looking to see anyone has any suggestion as to what to look for as I go. i'm going to look at the exhaust today I do not think its that though.
