Copied from the 2000 Ford Service Manual
Trim Panel —Rear Door, Expedition
Removal
Remove the window regulator switchplate (14524).
Disconnect the electrical connector.
Remove the rear door handle trim cover.
Remove the rear inside door handle.
Remove the door handle bolt.
Remove the rear door trim panel screws.
CAUTION: To avoid damage to the rear door trim panel, do not pull directly outward.
Lift upward and then outward to remove the rear door trim panel (27406).
Installation
Install the rear door trim panel.
Install the rear door trim panel screws.
Install the rear inside door handle.
Install the door handle bolt.
Install the rear door handle trim cover.
Connect the electrical connector.
NOTE: If a new trim panel is required: Some new trim panels have a cut out opening for the window switchplate that is larger than that on the original trim panel. When installing a new trim panel, install the window switchplate in the following sequence to make sure that the switchplate is secured fully into the door trim panel.
Install the window regulator switchplate.
Insert the rear switchplate clip into the trim panel opening.
Install the forward and side clips into the trim panel opening.
