Go Back   Ford Expedition Forum > Ford Expedition Forum > 1st Gen - 1997 - 2002
Register to remove these ads.
4 wheel drive selector stopped working
This is a discussion on 4 wheel drive selector stopped working within the 1st Gen - 1997 - 2002 forums, part of the Ford Expedition Forum category!
Yup it was working a week ago then last night went to put in 4 low to pull a drunk ...
Like Tree6Likes
  • 2 Post By Yudaman
  • 1 Post By BAD RONALD
  • 1 Post By bedrck46
Reply
Old 03-12-2014, 11:51 AM   #1 (permalink)
spud's Avatar
Default 4 wheel drive selector stopped working
Yup it was working a week ago then last night went to put in 4 low to pull a drunk idiots van out of the river and nothing happened, no lights no little clicks nothing. I was able to pull him out in the AWD mode and the front did grab so not sure what it is. Hope its simple like a fuse or something.
spud is offline   Reply With Quote
Old 03-12-2014, 12:03 PM   #2 (permalink)
Registered User
Default
Were you in neutral when you tried to shift into 4L?
crackhead is offline   Reply With Quote
Old 03-12-2014, 12:32 PM   #3 (permalink)
Yudaman's Avatar
Default
I had the same issue and started a thread on it.
'98 4x4 curiosity
Your answer may be there.
nonwoven29 and spud like this.
__________________
'98 Eddie Bauer 5.4L 4x4 200k+ miles
Gotts mod
Flowmaster 40 catback exhaust with 3" tailpipe
Coil spring conversion
ZF5 Manual transmission <-- click for thread
SCT Tuner and half-assed custom tune by 5 Star Tuning
Yudaman is offline   Reply With Quote
Old 03-12-2014, 06:08 PM   #4 (permalink)
spud's Avatar
Default
Okay nice warm evening when it happened.
Yes tried to put into neutral several times and no luck.
Okay new information: I had a check engine light on at the time (P0401 EGR issue of some sort) This issue only happens after prolonged highway speeds (65+MPH for at least 40 minutes) Okay so i cleared the code and the 4x4 selector started working, drove it again the check engine light came on after a period of highway driving for the same P0401 code and the 4x4 stopped working, cleared the code and 4x4 selector working again.
So what ties a P0401 issue to being able to select what part of 4x4 you want? I mean its not what I want but for as often as I would ever use the selector I guess I could just clear the code as needed.
Old 03-12-2014, 06:40 PM   #5 (permalink)
Default
Check out this video:
If you correct the EGR malfunction and the 4wd problem persists you'll know they aren't related.
spud likes this.
BAD RONALD is offline   Reply With Quote
Old 03-12-2014, 07:58 PM   #6 (permalink)
bedrck46
Guest
Posts: n/a
Default
For the P0401 I would suggest that you clean the exhaust port thru the throttle body. You will need to remove the throttle body to do this Also you may need to change the DPFE sesnor as well I had that problem on a 99 and did the exhaust ports first and then still had the code reappear and had to change the sensor
spud likes this.
Old 03-17-2014, 03:58 PM   #7 (permalink)
spud's Avatar
Default
Thank you all, it was clogged holes on the throttle body. I traded my computer labor (fixed his issues with some viruses he had and such) while he fixed my problem, love swapping expertise for expertise, its like free money.
My little port holes had "whiskers" was plumb sealed shut and the big tube was about 1/2 the diameter it should have been with crud in it. Now all clean, took it for a drive and no light came on.
Again thank you all, it helped me diagnose the issue so i could trade out the work needing done, when your body is shot and the brain works its good to do this since I cant climb into the engine compartment myself.
Next project, getting the AC figured out as to why it dont work, will vacuum it down and see if it leaks off 1st then fill and see what happens.
Old 03-17-2014, 04:08 PM   #8 (permalink)
Default
Originally Posted by spud View Post
... it was clogged holes on the throttle body. I traded my computer labor (fixed his issues with some viruses he had and such) while he fixed my problem, love swapping expertise for expertise...
The tech who did the engine work probably appreciated the barter as much as you do.
From each according to his ability. A win-win.
spud likes this.
Old 03-17-2014, 04:09 PM   #9 (permalink)
bedrck46
Guest
Posts: n/a
Default
Don't be surprised if the light returns if it does I would suspect that the DPFE sensor would need to be replaced
spud likes this.
Old 03-17-2014, 04:29 PM   #10 (permalink)
TactialMonkey's Avatar
Default
The 4x4 fuse may be out as well its just a thought and my truck has the same code so ill look into that but I'm going to change my tcase out for a 4407 manual shift with my new 5 speed hopefully some time soon
__________________
TactialMonkey is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
