AWD EXPY
Last week I changed the front pads. Some were just broken. When I squeezed the caliper piston in, a squirt of dot 3 shot out. So I knew I needed to do a rebuild. This in on a 2 year old caliper. So I monitored the fluid level and topped it off once. I had soft braking action.
Today I did the caliper rebuild and bleed, and thought all was good, until I did a test drive. The pedal went to the floor. The steel line going to the rear had rusted, and that's where my fluid was leaking from. Just in front of the back wheel.
So I get to have some more fun changing that out. I'm going to install a union somewhere along the frame. This truck is not a keeper. I just need it to run a few more years.
I understand that it's a 3/16" line going back. Any tips on the procedure?
