Go Back   Ford Expedition Forum > Ford Expedition Forum > 1st Gen - 1997 - 2002
Register to remove these ads.
Heater blows cold air?
This is a discussion on Heater blows cold air? within the 1st Gen - 1997 - 2002 forums, part of the Ford Expedition Forum category!
Hey guys, Recently noticed in my wifes 99 5.4 eddie bauer expedition that when the heat is on it blows ...
Reply
Old 10-31-2011, 12:29 PM   #1 (permalink)
Registered User
Default Heater blows cold air?
Hey guys,
Recently noticed in my wifes 99 5.4 eddie bauer expedition that when the heat is on it blows ice cold air and then after 30 minutes or so it is room temperature air. It never gets hot or even close to warm. Any ideas where to start checking on this? Ive never messed around with heater components in any car before so this is all new to me. Ive red alot that the blend door is an issue in expeditions... would this be a good place to start? Thanks!
shart is offline   Reply With Quote
Old 10-31-2011, 12:51 PM   #2 (permalink)
thebeast1190's Avatar
Default
Check the coolant for the heater core.
__________________
99 EB
thebeast1190 is offline   Reply With Quote
Old 10-31-2011, 12:57 PM   #3 (permalink)
tarafied1's Avatar
Registered User
Default
sounds like it might be low on coolant, I'd check that. The blender door issue wouldn't effect the heat, just the vents opening.
__________________
2011 Taurus, 93 Mustang, 67 Mustang & 2000 Expy- Eddie Bauer
http://expeditionforum.com/image.php?type=sigpic&userid=40155&dateline=1315676791
Married to TARA, that makes me the TARAfied1
tarafied1 is offline   Reply With Quote
Old 10-31-2011, 12:58 PM   #4 (permalink)
Registered User
Default
This might be a dumb question, but you mean just check the coolant hose to the heater core correct?
Old 10-31-2011, 01:54 PM   #5 (permalink)
Registered User
Default
I have to jump in here, my 1999 is doing the exact same thing. So far they are telling me it is probably the heater core in the front. Could be the blend door. I had a shop last winter flush the entire system and it did not solve the issue so I believe the heater core is plugged or something. Doing it yourself looks doable but very time consuming. They are quoting me 7 hours just in labor at a shop, ouch! Good luck bro, let me know what you come up with as I have to address the issue here as well. Thanks
seansolo is offline   Reply With Quote
Old 10-31-2011, 02:21 PM   #6 (permalink)
Registered User
Default
From what im reading, if the heater core needs to be replaced the wife is on her own... lol. The 7 hour qoute is pretty much right on and they will use all that time to do it... So replacing it myself it will probably take alot longer since i am not familar with everything. Im going to try a few things... Flush the coolant system, flush the heater core, and pull off the heater core hoses (if i can get to them) and make sure they are not clogged... Other then that its probably going to have to go into the shop or she is going to have to live with it..
Old 10-31-2011, 03:10 PM   #7 (permalink)
jrjr's Avatar
Default
With you truck warmed up both heater hoses should be hot... not warm, hot. If only one is or neither then you may have a plugged core. If both are hot then there is flow through the core and its most likely the blend door not opening due to either a bad actuator motor or a broken blend door tube.
7 hours is a low average I'd say. I just did mine. The dash was pulled back in 4.5 hours and probably another 4 to get it back together. Of course I had never done it before and someone with experience at this job should be able to do it faster. If you do pull it, or the hoses, replace the o rings.
Here ya go-
__________________
A Nation of Sheep Breeds a Government of Wolves!
1997 XLT 4.6
________________________
Jack
jrjr is offline   Reply With Quote
Old 11-04-2011, 11:57 AM   #8 (permalink)
walnuts4x4's Avatar
Default
if blend door is broke it will allow for either only AC or HEAT... mine was broke and I only had AC so I went with "heatertreater" cheater method for fixing it... basically a 2 part blend door that requires a little hidden cutting and allows fixing without removing the dash... plus the door is a metal door that wont break like the stock ones do
__________________
2012 Jeep Patriot....
Formerly a 99 expy with 11" lift and 37s...
walnuts4x4 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
