Fellas, I could use some help with the brown wire mod I keep reading about, as I absolutely hate the thought of my AWD kicking on and off constantly.....the wear and tear on parts worries me a bit.
I read quite a bit on it and decided to go about it a bit differently.
It seemed to be that the best option was to run 2 wires out of fuse 104 under the hood (4x4 and clutch motor) to a relay. I wired the relay according to the diagram and then to a switch, all properly grounded.
Here's my problem, as per diagram I get no juice to the switch (check with voltmeter) I found the powered pole of the relay and switched one of my switch wires to that and I now have power to the switch, but it seems to be jumping through the relay, because I now can not control the 4x4 with my new on/off switch.
Could any of you guys provide me with a generic relay diagram or offer any ideas?
If I would have realized how ackward this relay would be I would've just bought a 30amp on/off switch and be done with it, which is what I have resulted to for now as our michigan roads seem to be getting snow here and there.
Any ideas? Thoughts?
Sorry for the horrible explanation, hope you guys can follow what I mean.
