How to change radiator
l1j2h
port Hardy
I just need to replace the radiator in my 1999 Expedition EB full options with sunroof .
I need to buy radiator.
But when I research it, it seems two kinds with towing package or without towing package.
Which one should I buy?
And should I remove fan blade or not?
Thank you so much for giving your experience.
Please help me. And give me some direction for me.
Bedrck47
Elizebethtown, PA
Best to use a two row Radiator Also would be easier to remove the fan blade You made need a special tool which you can borrow/rent from most auto parts stores. Removing fan blade makes it easier to remove the fan shroud and radiator. You may also want to consider replacing the Radiator hoses Upper and Lower and maybe a new T/stat.
L
l1j2h
port Hardy
qw
I am sorry about this question again.
Which one is two row Radiator?
Is it the same size ?
Please give me info.
Do you think that I should the Radiator hoses Upper and Lower and a new T/stat?
Thank you for giving your info.
I am waiting for your answer... ^^;
All good friends here. ^^; I am so happy.
98eb5.4
s. ontario
2 row is bigger, need it if truck is used for anything heavy duty like towing, plowing etc,
hoses & t-stat if, or don' know how, or looks/feels old,
i took my rad out without pulling the fan but wasn't easy, separated/disconnected the upper & lower fan shrouds then twisted the bottom one out, top was easy
Bedrck47
Elizebethtown, PA
The expy will fit either a single row or double row radiator The outside dimensions width and height are the same the thickness is different but either will fit. Yes the rad can be removed without pulling the fan but why fight it. Get the tool to help remove the fan and as I posted earlier replace the hoses. Better to have new everything than risk having problems thru the winter.
Bedrck47
Elizebethtown, PA
Fan
Special Tool(s)
Fan Pulley Holding Wrench
303-239 (T84T-6312-C)
Fan Clutch Wrench
303-454 (T93T-6312-B)
Removal
WARNING: Do not run the engine while the protective components are removed. Failure to follow these instructions may result in personal injury.
NOTE: The fan clutch and shroud must be removed as an assembly.
1. Drain the engine cooling system. For additional information, refer to Cooling System Draining, Filling and Bleeding in this section.
2. Remove the air cleaner outlet pipe. For additional information, refer to Section 303-12 .
3. Remove the front air deflector (19E525).
1. Remove the screws.
2. Remove the front air deflector.
4. Remove the upper radiator hose (8260) from the radiator (8005).
5. Remove the fan blade (8600) and fan clutch.
1. Use Fan Clutch Holding Tool to hold the water pump pulley (8509) steady.
2. Use Fan Clutch Wrench to remove the fan blade and the fan clutch.
6. Remove the fan shroud (8146).
2. Lift and remove the fan shroud and fan blade out of the vehicle together.
7. Remove the fan and shroud out of the vehicle together.
8. Separate the fan clutch from the fan blade.
1. Remove the bolts.
2. Separate the (A) fan blade from the (B) fan clutch.
Installation
1. Assemble the fan clutch to the fan blade.
1. Position the (A) fan clutch on the (B) fan blade.
2. Install the bolts.
2. Position the fan shroud and the fan blade.
3. Install the fan shroud.
1. Lower the fan shroud onto the radiator clips.
2. Install the screws.
4. Install the fan blade and the fan clutch.
1. Position the fan blade assembly and the fan clutch on the water pump pulley.
2. Use Fan Clutch Holding Tool to hold the water pump pulley steady.
3. Use Fan Clutch Wrench to install the fan blade and fan clutch.
5. Connect the upper radiator hose to the radiator.
6. Install the front air deflector.
1. Position the front air deflector.
7. Install the air cleaner outlet pipe. For additional information, refer to Section 303-12 .
8. Fill the engine cooling system. For additional information, refer to Cooling System Draining, Filling and Bleeding in this section.
Bedrck47
Elizebethtown, PA
Radiator
Removal
2. Remove the fan blade (8600). For additional information, refer to Fan in this section.
3. NOTE: To avoid disturbing the transmission oil cooler fittings, use a backup wrench.
Disconnect the transmission fluid cooler fittings.
1. Disconnect the upper transmission fluid cooler fitting.
2. Disconnect the lower transmission fluid cooler fitting.
4. Disconnect the lower radiator hose (8286) from the radiator (8005).
1. Pry the locking tab up and out of the slot.
2. Rotate the lower radiator hose.
3. Disconnect the lower radiator hose.
5. Remove the radiator.
2. Remove the upper radiator support brackets and the jack handle and wheel nut wrench retainers.
3. Lift the radiator off the radiator mounting insulators (8124).
4. Remove the radiator mounting insulators.
Installation
1. Install the radiator.
1. Install the radiator mounting insulators.
2. Position the radiator on the radiator mounting insulators.
3. Position the brackets and the jack handle and wheel nut wrench retainers (17A038).
4. Install the bolts.
2. Connect the lower radiator hose and upper radiator hose (8260).
1. Push the hose onto quick connect fitting.
2. Bend the locking tab into retaining slot.
AbbadonTD
if you want to know which radiator you have, you can run your VIN on ETIS, and if it says "factory towing package" than you have the larger one.
L
l1j2h
port Hardy
Thank you so much
Spectra Premium CU2136 Complete Radiator for Ford
by Spectra Premium
Be the first to review this item
Price: CDN$ 199.18
I ordered this one from Amazon ca. I will receive it after 10 days..
Maybe...
Thank you for giving me instructions.
I will do this job later.
I am so happy with you all.
From Paul
