It could be the indicator stalk if neither the indicator or signal is working. Do you use the telescoping feature (tilting up and down) on the steering wheel a lot?
The stalk is what turns the blinkers and windshield wipers on and off. The switch if you will. Yes it is replaceable. I think it is pretty similar to this:
thanks for the video. looks like a lot of work. I think I'll just deal with the front left signal not working. the backs work fine. the right sides work perfect.
move the steering wheel up and down trying it in all postions if so I have to tighten the plug on mine every now and then (take plastic off around steering wheel column and push plug on just a tad tighter)
