question about tranny noise
marn
missouri
my tranny makes metallic noise till it hits 3rd gear also makes noise when kicked into passing gear. tranny has 1000 miles on new filter and fluid vehicle has 196000 been great vehicle. torque converter or need new transmission?
stamp11127
Temple, Georgia
The bus shop I used to work in, any time we suspected internal trans problems first thing we would do is to drop the pan and inspect the fluid with a bright flashlight. If it had a metal-flake appearance we would swap out the trans. Never had a torque converter fail, but did split a few flex-plates. I know these aren't the same, but it is what it is......
At that mileage even if it was the torque converter I would swap trans since it is basically out anyway.
joeyg23832
VA
Sounds like you have a set of planitary gears failing... Wouldn't bother with rebuild just replace...
M
marn
missouri
when overdrive light started flashing was afraid of major problems how long will it last ??
joeyg23832
VA
I have heard of guys going 3-5 thousands miles with broken\no overdrive wouldn't recommend it though. There is a retaining ring that fails on one of the clutch units, it causes loss of overdrive and the overdrive servo breaks its retaining ring. Slowly starts to tear itself apart. Been a known problem from Ford for many years but I have rebuilt trans as new as 2005 with same problem.
