Go Back   Ford Expedition Forum > Ford Expedition Forum > 1st Gen - 1997 - 2002
Register to remove these ads.
Replacing the rear heater core
This is a discussion on Replacing the rear heater core within the 1st Gen - 1997 - 2002 forums, part of the Ford Expedition Forum category!
This morning I smelled coolant while driving and when I stopped I saw coolant dripping out of a hose at ...
Reply
Old 10-24-2011, 12:25 PM   #1 (permalink)
mmrseed's Avatar
Default Replacing the rear heater core
This morning I smelled coolant while driving and when I stopped I saw coolant dripping out of a hose at the rear of my 99 expy. It appears that I may need to replace the rear heater core. Is this something thatan average joe (my name's not joe) should be able to do outside of the a/c flush and recharge? It doesn't seem difficult...just disconnect the old core from the hoses and replace....am I missing some secret hidden difficult issue? Thanks all
__________________
99 5.4L w/Fabtech suspension lift, 35" bfg's, headers, flowmaster exhaust jvc dvd w/flipdown and ps2
mmrseed is offline   Reply With Quote
Old 10-24-2011, 07:11 PM   #2 (permalink)
mmrseed's Avatar
Default
nevermind...got it done...3 hours to tear down....20 minutes to put it all back. What an education
__________________
Old 10-24-2011, 07:16 PM   #3 (permalink)
toms89's Avatar
technical advisor
Default
No photos or how to details? :(
__________________
Blown 2000 XLT 4wd...12.61 @ 107.44mph. (481 rwhp & 577 rwtq)
http://www.youtube.com/watch?v=QW7XKRvOP0Q
Built 5.4 w/ 8.6 to 1 comp, forged manley rods & pistons, forged steel crank, comp cams 102500, trick flow heads, ported lightning supercharger assembly pullied for 14psi boost. Tuned by self via SCT pro-racers software.
Built 4R100 . Complete custom mandrel bent dual 3" stainless exhaust with high flow cats.
toms89 is offline   Reply With Quote
Old 10-24-2011, 07:48 PM   #4 (permalink)
mmrseed's Avatar
Default
too stressed at the time to take pics but it basically boils down to-
drain radiator (luckily mine was mostly drained thanks to this stupid heater core)
open rear hatch and remove
- rear seat
- rear hatch skid plate
- c pillar plastic cover (driver side) (you will need to disconnect seatbelt)
- b pillar plastic cover (driver side) (you will need to disconnect seatbelt)
- rear A/C plastic vent (thick black tube right under the b pillar plate)
- 2nd row seating skid plate
- plastic kick panel to expose the rear heater core assembly (there is a hidden pin under the carpet attaching it to the floor of the truck)
Disconnect the two hoses at the bottom of the heater core assembly
Then loosen and disconnect the two bolts on the metal tubing for the A/C (be careful you will get some green dye spray as the refridgerant blows out, so loosen lightly at first and it will just drip down through the floor of the truck)
Disconnect the 7 parts to the wiring harness from the truck to the plastic heater core assembly (you cant miss them)
Loosen the two brass bolts holding the assembly to the truck
Turn the assembly over and there will be 10 small bolts to take off and underneath that is the heater assembly...it just comes straight out. Replace and do the whole process in reverse.
I was quoted about $500 for this. The part was $60 and I will have to pay to recharge the a/c...that's it
__________________
Old 10-24-2011, 07:51 PM   #5 (permalink)
toms89's Avatar
technical advisor
Default
You da man! LOL
Thanks for the write up!
__________________
Old 04-24-2014, 09:15 PM   #6 (permalink)
Registered User
Default Here I go...
Looks like I get to tackle this job... Ugh!
Is coolant leaking from the rear heater core drip tube the indication that it needs replaced?
rixemailfl is offline   Reply With Quote
Old 04-24-2014, 10:00 PM   #7 (permalink)
Default
yeah, and as for the ac part goes, go to a dealer and have the gas recovered. you can rent the tools to re charge it yourself. I got 5 cans of r-134a for about $65 because I didn't wait and order it in bulk, you can get a 12 pack for $50 last I checked. it's $300 deposit on the tool rental but it's 100% refund when you're done.
also, I would inspect the orifice tube for abnormal debris and replace the high/low side valve stems while it is degassed. the high side valve tends to leak and the orifice tube can tell you if you have a compressor in pre failing stage.
IMINYOURCHAIR is online now   Reply With Quote
Old 04-24-2014, 10:00 PM   #8 (permalink)
Default
yes.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
