Go Back   Ford Expedition Forum > Ford Expedition Forum > 1st Gen - 1997 - 2002
Register to remove these ads.
Sea Foam
This is a discussion on Sea Foam within the 1st Gen - 1997 - 2002 forums, part of the Ford Expedition Forum category!
I have been thinking about using Sea foam on my 98 expedition with 211,000 kms and some change. Has anyone ...
Reply
Old 01-02-2012, 08:51 AM   #1 (permalink)
kevinw2345's Avatar
Default Sea Foam
I have been thinking about using Sea foam on my 98 expedition with 211,000 kms and some change. Has anyone used it on their vehicle with this many kms. I have heard good and some bad stuff so want some fellow Expedition owners opinions. Thanks Guys
kevinw2345 is offline   Reply With Quote
Old 01-02-2012, 09:24 AM   #2 (permalink)
ZombieSoldier's Avatar
Default
not the same thing, but i SeaFoamed a 1994 Ford E150 conversion van with a 302 and 176,000 miles on it. BOY did it give off a smoke screen!!!!!
__________________
2005 Expedition Eddie Bauer- GONE!
2008 F250 6.4 Powerstroke. 641rwhp of road shredding power!
ZombieSoldier is offline   Reply With Quote
Old 01-02-2012, 09:35 AM   #3 (permalink)
IAExpy's Avatar
Default
Using it how? Fuel system, crank case before an oil change, top end cleaning such as introducing through your brake booster? What is your goal?
IAExpy is offline   Reply With Quote
Old 01-02-2012, 09:42 AM   #4 (permalink)
Default
i did it through the brake booster method..
__________________
Old 01-02-2012, 10:47 AM   #5 (permalink)
SkyJumper's Avatar
Registered User
Default
Using the SeaFoam to clean the top end will require you to use it either in the fuel tank at fill up or thru the brake booster or vacuum line feeding the manifold.
Putting the SeaFoam in the oil before the oil change is cleaning the bottom end.
It depends on your reasoning of use to where you put the SeaFoam.
A smoke screen out the tail pipes will only happen when you use it directly into the manifold, ie: brake booster or vacuum line. And that is a good thing, it is doing what it is supposed to do, cleaning deposit build-up in the intake, valves.
SeaFoam is meant to only clean up the carbon build up through the top end, and oil build up deposits in the bottom end when used in the oil.
I usually add a can of SeaFoam every 4 or 5 fill-ups. It does all good and nothing bad. It is a great investment as a regular fuel additive. Only downfall to this method I use is if there is deposits in the fuel system it could clog up injectors or disturb the injector spray pattern. Other than that, it is a safe and clean method to help keep the upper end clean as possible. I virtually swear by the product as I have been using it for years and on all kinds of makes and models.
__________________
99 XLT 4.6 4x4, Full Spectre CAI, Edge EVO/HT tuned, Hooker Aero Chamber with dual Magnaflow 3" tips, 3/2" lift, 305/70/16 Nitto Terra Grapplers, 16x10 Pro Comp Xtreme black mods, Camo interior, Smoked Euro tail lights, Black Euro headlights, and more to come.
http://www.explorerforum.com/forums/...play.php?f=179
SkyJumper is offline   Reply With Quote
Old 01-02-2012, 11:14 AM   #6 (permalink)
tonydiv's Avatar
technical advisor
Default
I'd suggest a quick search of the forum. We've pretty much covered this subject to death.
__________________
1998 XLT 4x4 5.4, Rancho 4" lift w/RS9000 shocks, 3" Body Lift, 35" BFG AT KO on Weld Wheels, Tactical Armor Group Bumper, Tuff Stuff 12,500 lb winch, Rancho Skid Plate, Flares, Magnaflow SS Dual exhaust, Dual Optima Red Tops, Pioneer Touch Screen Nav Unit, Pioneer DVD w/ 7" Drop Down, Backup Camera w/ 10" Monitor SOLD 5/20/12 Replaced with a V10 Excursion Limited
tonydiv is offline   Reply With Quote
Old 01-02-2012, 11:04 PM   #7 (permalink)
kevinw2345's Avatar
Default
i am pretty much just looking to clean it, i know sometimes when i stop the truck starts to shake like the engine wants to stall so i want to give it a good cleaning inside.
Old 01-02-2012, 11:06 PM   #8 (permalink)
kevinw2345's Avatar
Default
i know some people swear by it, some people dont. Thats why i asked for opinions i have a year warranty on my truck right now so if the Sea foam reveals any problems it covers all internal parts for the engine. Thanks for the in depth response.
Old 01-02-2012, 11:12 PM   #9 (permalink)
panda24619's Avatar
Default
i used it in the gas tank and oil. and i used it threw the vacuum brake booster hose and it didnt really set off a smoke screen. nvy said it put out some, but not much. i should have put in a 2nd can but i didnt have one.
__________________
1998 XLT 5.4 4x4
DEAD!!!!
http://www.lalalalalalalalalalalalalalalalalala.com/
panda24619 is offline   Reply With Quote
Old 01-02-2012, 11:48 PM   #10 (permalink)
Default
That sounds kinda like a torque converter not wanting to unlock.... Or is after you come to a stop and within a few seconds after it does this?
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
