Go Back   Ford Expedition Forum > Ford Expedition Forum > 1st Gen - 1997 - 2002
Register to remove these ads.
Trans od light flashing....
This is a discussion on Trans od light flashing.... within the 1st Gen - 1997 - 2002 forums, part of the Ford Expedition Forum category!
While driving home from work yesterday I happen to look down at my radio and saw my OD light flashing. ...
Reply
Old 05-22-2013, 03:54 PM   #1 (permalink)
Default Trans od light flashing....
While driving home from work yesterday I happen to look down at my radio and saw my OD light flashing. I was doing about 65-70 and did not notice and shift problems until i got off the exit and noticed a very slight bump when it was going into 2nd and then third gear. I pulled over shut it off then back on and no more light or bump i drove around for another hour and it never happened again. then again this morning at the same speed it did it again so i again cut it off and started it back up and it went away i have been driving all day with no issues. where are the codes stored from the tranny? i went to auto zone and got the cel scanned and got a code p0401 and something about bank one oxygen sensor. any ideas?????
__________________
215Expedition is offline   Reply With Quote
Old 05-22-2013, 04:16 PM   #2 (permalink)
toms89's Avatar
technical advisor
Default
O/D light flashing means the pcm has recognized an issue with the transmission. Can be many things....
Resetting the light is not going to make the problem go away so just drive normal. Unfortunately I do not believe you can read any codes related to the tranny. May have to go to dealer or transmission specialty shop.
__________________
Blown 2000 XLT 4wd...12.61 @ 107.44mph. (481 rwhp & 577 rwtq)
http://www.youtube.com/watch?v=QW7XKRvOP0Q
Built 5.4 w/ 8.6 to 1 comp, forged manley rods & pistons, forged steel crank, comp cams 102500, trick flow heads, ported lightning supercharger assembly pullied for 14psi boost. Tuned by self via SCT pro-racers software.
Built 4R100 . Complete custom mandrel bent dual 3" stainless exhaust with high flow cats.
toms89 is offline   Reply With Quote
Old 05-22-2013, 05:05 PM   #3 (permalink)
Default
OK thanks for the info, I might have to take it to a transmission shop to get it looked at. I don't think its anything bad as of yet because it comes and goes but i hope its a simple fix.
__________________
Old 05-28-2013, 10:14 AM   #4 (permalink)
BANGEREXPO76's Avatar
Default
I had this similar problem and It is probably not your trans. I took mine to the trans shop first and he was a good fellow and told me I didn't have a problem. He had it hooked up to the big mobile scanner. Being that you have code 401 I'm guessing your cat converters are clogged. Mine were clogged up with what looked like concrete. They were so bad I had them leave the rear ones off and run straight pipe. The truck instantly ran GREAT and still does to this day!!! I also replaced all 4 O2 sensors. Just throwing that out there. Good luck with yout truck.
__________________
BANGER
1997 FORD EXPEDITION EB 5.4 4x4
CAI, 8k H.I.D., JVC HU, 275/55/20, CUT CATS, otherwise VERY STOCK.
BANGEREXPO76 is offline   Reply With Quote
Old 06-11-2013, 11:13 PM   #5 (permalink)
Registered User
Default same issue
i had a 99 expo that the OD light was flashing on it if im correct you can count the flashes and it will be the code the reason mine was flashing was because of the shift modules so i watched you tube to see how to change the shift modules and i tackeled it one weekend and changed all 3 shift modules and the wiring cost me about 50 in parts and no more flashing od and that was about 2 years ago still running strong with 250,000 on it
Firepuppy is offline   Reply With Quote
Old 06-12-2013, 12:08 PM   #6 (permalink)
Default
Come to find out the egr valve was clogged took it off and cleaned it and now no problem.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
