Window keeps dislocating
AWD EXPY
Piqua, oHIo
My passenger front window can't seem to stay in the track part that lifts and lowers it. It wants to jump out and be off track when coming up. I've tried gorilla glue and hot glue. That only works for a few times.
Is there a better solution (cheap) to keep the glass attached to the regulator?
Thanks in advance.
captain chaos
in a van down by the river
I had that problem shortly after buying my Expy. Use some coarse sandpaper to rough up the bottom 1" or so of the glass where it sits in the channel. Then use copious amounts of epoxy (JB WELD) to 'glue' it in place. Roughing the glass helps a lot as it gives the epoxy something to 'bite' into.
A
AWD EXPY
Piqua, oHIo
Yesterday I used the sandpaper then cleaned it with alcohol. Applied jb weld, and will give it a couple days to set.
IMINYOURCHAIR
Altoona Alabama
forgot to mention, I used the 4 hr cure stuff. had to put the window in my house for the day because it was 30f out when I did it.
A
AWD EXPY
Piqua, oHIo
I shoulda used the quick set stuff, but it worked at least once yesterday. Winter will be the real test.
