kwyorman
I have a '97 E.B. with a gauge problem. When I start the truck everything works fine. But after a few minutes the water temp and oil gauges go full max, the voltage gauge and the fuel gauge just kind've float up and down. They stay that way until the truck is turned off and restarted. I've checked the voltage coming through the system and it reads fine and is rock steady. Also the audio from the radio cuts out even though the radio is on. Its an aftermarket radio and I checked the audio output with a known good speaker at the radio connector and I get audio, so that problem is something to do with the amplifier. Any quick ideas? Anyone come across this before?
