Rear Overhead Louver Vent Removal
ExpyKen
Arlington, VA
Hello Everyone,
One of my boys tapped the overhead louver vent (behind the front passenger seat) a bit too hard and broke a couple of the louvers - I have a new one on order but can't seem to determine how, exactly, this piece is removed. Can anyone help?
Thank you!
Bedrck47
Elizebethtown, PA
Register
Removal and Installation
Fabricate a removal tool from a 1/8-inch diameter rod.
Rotate the A/C register with the removal tool to align the retaining ears with the clearance openings and remove the A/C register.
To install, reverse the removal procedure.
E
ExpyKen
Arlington, VA
Well I'll be darned - I would have never, ever guessed that to be the removal method! Thank you so much, Roxy!
Register
Bedrck47
Elizebethtown, PA
Your Welcome
The tool really isn't needed once you figure out where the retaining ears are but I thought this would be the easiest way for you
and hopefully others
Bedrck47
Elizebethtown, PA
kindly update your signature line with year model and engine information. This can be done in the USER CP section as this information helps others give you replies specific to your expy
hsquared360
