"Low Oil Pressure" in Message center...
G
Guest
Guest
I get low oil pressure message at startup, get it even before the truck is started up. Oil level is OK.
I also get a low tire pressure... nothing is low there unless the spare is wanked.
Is there a reset besides hitting it every startup?
I'll call the dealer tommorow and see what they say but we've not have this truck 6 hours. Poop.
daveplot
If you turn the truck to "on" without starting it will say low oil pressure. This is normal since the oil isn't flowing around the engine.
frank1971
