try unplugging the amp at the amp...turn it on and see if it still pops...did you use a wiring harness or spliced all connections to factory wiring? since u got a dead battery afterwards im thinking its the remote wire still having power...if u still get a pop after unplugging the sub amp it is definitely in your wiring and the power source wires...did you connect the antenna wire? i dont think i connected the antenna wire on my pioneer avic-d3...but the remote wire is connected...if it still doesnt help...idk...i would suggest going to an audio shop if this doesnt get u closer...
