Buying used wheels/tires question
hondoford
Cypress, TX
I've worked out a deal to buy a set of 20" 2015 F150 wheels and want to install them on my 2014 Expedition Limited (link to pic of wheels I'm buying is below).
I'm new to trucks/SUV's and just wanted to confirm that
1. They will fit? I'm pretty sure they will, I believe the same wheel is an optional wheel for the 2015 Expedition.
2. Will the TPMS sensors from my 18" wheels work on the new ones?
3. Since I have 18" wheels, will my spare still work. Is overall diameter of the tires the same (or close enough).
Thanks in advance.
https://www.dropbox.com/s/mc5wklrsa26i02z/image-3275704193.jpg?dl=0
tallsville
LA
They should be the same bolt pattern. Im not sure about the tpms as i dont have that, but im sure someone will answer that. The rim size doesn't make a difference, it's the diameter of the tire that matters. A 35" tire is a 35" tire, whether its on a 15" rim or 20" rim. A 305/60/18 is within 1/2 inch diameter of a 285/70/17. I've ran my regular 32" with my 33" tires.
Here is a link for tire comparison
http://www.rimsntires.com/specspro.jsp
46L281GT
KY
Best way to find out about the tpms would be look at the part miner for sensors for the f150 vs yours. If they are the same then you know that they will work.
H
hondoford
Cypress, TX
Thanks very much for the replies! I just picked them up about a half hour ago and will have them on tomorrow.
Hampton, VA
2 types of tpms...band and stem...if its the stem u can have ur truck programmed to use those already in it...if it doesn't work for some reason...take urs out of ur current wheels and use them...that's what I did with my 24s and now 26s...im using the stock sensors
tifanydire
