Wheel offset help needed.
Wifes Nightmare
illinois
I have a 2015 Expy XLT that I'm going to change the wheels on, my question is about offset. The wheels I'm looking at are KMC XD Series Monster 18X9's, but I'm undecided on the offset choice. They either come in 35, 18 or -12 offsets, My stock wheels are a 44 offset.
Hampton, VA
u can do the 35mm...are you doing a lift? the offset deals with the back spacing of the wheel...so the 35mm may stick out some from the truck and the -12 should tuck inside wheel well
rockyw123
alabama
I have an 07 and I just put new 22 x9.5 with a 30mm off set. Why do the front wheels look like they stick out farther then the back? Is this a common problem?
reece146
ON, Canada
Most vehicles have a wider track in the front than the back.
This helps with turning radius and high speed dynamic stability.
