tigernation653
All original OEM suspension, 2WD, Non-Air. The ride is getting real loose and there is a lot of bumping, knocking suspension travel sound at low speeds. I want to start replacing components to restore handling and safety. The vehicle is in great shape otherwise (one owner, well maintained), only uses 1 quart of oil every 2k miles, so I plan to keep it another 100k miles. I don't want to replace everything at once, so where should I start and how much should be replaced. I know shocks and struts, but what about springs, ball joints, tie rod ends, sway bar bushings and so forth?
