Go Back   Ford Expedition Forum > Ford Expedition Forum > Tech Info
Sponsored Ads
Register to remove these ads.
Tech Info
anybody a smart guy on the electrical system?
This is a discussion on anybody a smart guy on the electrical system? within the Tech Info forums, part of the Ford Expedition Forum category!
Register to remove these ads. It's free! hey i installed a new cold air intake AFE i think but when ...
Reply
Old 05-01-2011, 05:50 PM   #1 (permalink)
Registered User
Default anybody a smart guy on the electrical system?
hey i installed a new cold air intake AFE i think but when i installed it used all the factory sensors no big thing but i got a trouble code from the AIT sensor i believe it is the temp sensor for the intake original thought was that i boogered it up putting it back in so i replaced it but even after that and clearing the code no joy it came back with intake temp to high or some mess... i am really thinking just to jump the stupid thing and bypass it so the check engine light will turn off.... what do you guys think and has anyone else had a problem with this? or have a schematic and could maybe help with the bypass?
oh yeah this is a 2000 EB 4WD with 5.4L and this seemed kinda technical doing a stock bypass but this may be in the wrong spot i am kinda new to the forum world
clardy is offline   Reply With Quote
Old 05-01-2011, 08:28 PM   #2 (permalink)
WHOISMOOTOO's Avatar
Default
did you install it backwards by chance?
__________________
2005 EDDIE BAUER (2WD)
24X10 (305/35/24) GIOVANNA CANELLI'S, PTM OXFORD WHITE MIRROR CAPS, FLOWMASTER 40 SERIES MUFFLER w/ CUSTOM TIPS, PIONEER AVH-P4300DVD DOUBLE DIN DECK, SOUNDSTREAM DVD, 2-KENWOOD 1800W AMPS, 4-KENWOOD 1200W 12"SUBS IN 2-TURBOBASS PROBOXES, 2 7" POWER AKOUSTIK HEADREST TV'S
WHOISMOOTOO is offline   Reply With Quote
Old 05-01-2011, 09:41 PM   #3 (permalink)
tonydiv's Avatar
technical advisor
Default
I don't think that jumping it will solve the problem.
tonydiv is offline   Reply With Quote
Old 05-01-2011, 09:42 PM   #4 (permalink)
Racenut's Avatar
Default
If you try and do a bypass you will get CRAPPY MILAGE AND POWER!
The computer uses the AIT to adjust the fuel and timing curves so if you bypass it you will either have issues in cold weather of not getting enough fuel, and in the summer you could actually be overfueling and spitting raw gas out the tail pipe.
__________________
______________________
2002 Expy EB 5.4L 2wd
CAI
Flowmaster 70 series
Rear cat and Y pipe delete
Smoked corners, tails, and third brake light
2 Hella 500 FF behind grille
8000K HIDs Heads and Fogs
Soon to come
Shorty Headers
3.5" Fabtech 2wd lift kit
33" Tires
Racenut is offline   Reply With Quote
Old 05-02-2011, 07:16 AM   #5 (permalink)
Thermo's Avatar
technical advisor
Default
Clardy, I would first try getting a new AIT sensor and seeing if that will help your problem. The sensor is cheap and easy to install. I would also do a once over of the wiring and look for any sharp bends in the wiring (this would indicate a broken wire, leading to a high indicated temp to the computer).
If you need more info, I will see what I can dig up for you. I don't have my normal assortment of technical info for the parts of your truck, but I am sure I can figure out what you are needing to know using other things that are available online.
Thermo is offline   Reply With Quote
Old 07-25-2011, 10:57 PM   #6 (permalink)
Default
boy I hate to speculate so I'll list any causes I can think of. lets troubleshoot.
MAF is installed backward, the sensor on top of the MAF is mounted 180, It is still sucking hot air from the engine compartment (box installed improperly or not at all), twisted or broken wire, mis-connected wire, bad air fliter,
also try unhooking the Negative battery cable for about 10-15 minutes, hook it back up then start the truck and let it run at idle for about 10-15 so it can re-calibrate for the new airflow coming in, (if you haven't done the GOTT's mod give it a try, $20 and 45 minutes), during install an unseen connection was disrupted check all surrounding plugs for secure connections/tight wire crimps etc., vacuum hose??
those are all the things I can think of in that system that could fail for any reason, I think it's probably free to check them all yourself. before you guess at a sensor.
dj_mindframe_99 is offline   Reply With Quote
Old 10-07-2011, 09:37 AM   #7 (permalink)
Registered User
Default
never got back after the replies thanks guys i ended up retiring that truck due to terminal cancer (rust) so i couldn't lift it but still have the parts so i will be trying again on the 99 i bought
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
