09-26-2011, 08:41 PM
#9 (permalink)
technical advisor
Baker, it is not the oil cooler. The oil cooler is tucked on the side of the engine and has engine coolant to "cool" the oil. Notice my quotes. If you look at the hose that runs on the drivers side of the engine, if you see 2 small hoses come off of that about 2" apart from the same hose, then you have the oil cooler. Also, if you have the remote oil filter, you have the oil cooler.
Personally, the "oil cooler" is a marketing thing. You are running hot engine coolant through the cooler and the 2 lines feeding the cooler come off of the same engine coolant line 2" apart. How much coolant flow are you really getting through that "cooler". I tore mine off of the truck and went back to the straight on the block filter. But then, I have enough room on the front of my truck that removing the oil filter is easy. Hell, I don't even need any tools any more to change my oil. I slide a 5 gallon gas can under the truck, slide in my special tube to drain the oil directly into the 5 gallon gas can and then I use a little drip tray to catch what falls out of the filter as I spin it off the engine. Changing the oil is so much easier now that I spent a few bucks. Granted, kinda hand to because the lift was right in the way of where the oil drained and if I didn't do what I did, oil would end up everywhere (how do I know? Think about it). What a mess that was.
__________________
Official Member of the Lifted Expy Club
