Go Back   Ford Expedition Forum > Ford Expedition Forum > Tech Info
Sponsored Ads
Register to remove these ads.
Tech Info
Misfire cylinder 7
This is a discussion on Misfire cylinder 7 within the Tech Info forums, part of the Ford Expedition Forum category!
Register to remove these ads. It's free! Had my check engine blinking on me a couple weeks ago and took ...
Like Tree1Likes
  • 1 Post By timberwoof
Reply
Old 01-16-2012, 02:01 AM   #1 (permalink)
timberwoof's Avatar
Default Misfire cylinder 7
Had my check engine blinking on me a couple weeks ago and took it to autozone to get it read. Came out as misfire in cylinder 7. The guy said it may be the coil is bad. At the time I was thinking basically the same thing but it never happened again until a few minutes ago. What are your opinions on the matter?
Prettybrown izs likes this.
timberwoof is offline   Reply With Quote
Old 01-16-2012, 10:23 AM   #2 (permalink)
Big Red Monster's Avatar
Default
how old is ur truck and have u ever had a tune up? right now mines at the shop, needs new spark plugs and prolly a coil or 2. this seems to be a common problem, only problem is mine wont throw the damn cel, which makes it harder for the mechanic to figure out whats wrong.
__________________
2002 Ford Expedition Eddie Bauer
Big Red Monster is offline   Reply With Quote
Old 01-16-2012, 10:30 AM   #3 (permalink)
timberwoof's Avatar
Default
2006 with 85k on the clock
Old 01-16-2012, 10:40 AM   #4 (permalink)
Default
ohh 3 valve motor, i have heard alot about the plugs breaking off in the heads on those. i would just change the coil, my dad had the same problem with his 97. changeing the coil fixed the problem
__________________
Old 01-16-2012, 11:31 AM   #5 (permalink)
Registered User
Default
i had the same thing happen to my 07. you need to do a tune up on it. change the spark plugs and the coil on #7. I would recommend doing this soon before you have more problems. Over christmas we had this problem when we were traveling. wound up at two different dealerships and had three coils changed and the sprak plugs. before you get into the problems that i ran into i would do a tune up. the spark plugs can break really easy on these, the dealers use a cleaner that breaks up the carbon the on the plugs so they dont break.
wiley84 is offline   Reply With Quote
Old 01-16-2012, 12:41 PM   #6 (permalink)
Dib52's Avatar
Default
I had similar issues on my 08 but no CEL. We had to run a power balance through the OBD port to determine that cylinders 2 and 5 were the issue. Changed the coil packs on those two cylinders and problem solved. Having the info that cyl 7 is the problem, just swap it out with a new coil, about 45 bucks. With 85k on the ticker, might want to think about a full plug change, but they can be a real PITA if they decide to break like most do.
__________________
2008 Eddie Bauer 5.4L 4x4, HyperTech Max Energy, K&N FIPK, MagnaFlow Stainless Exhaust, Truxxx Spacers 3/2, Nitto Terra Grapplers 265/70/17(for now), Heavy Duty Trailer Tow Package, 3.73 Rear
Dib52 is offline   Reply With Quote
Old 01-16-2012, 09:20 PM   #7 (permalink)
timberwoof's Avatar
Default
I've been watching several different YouTube videos on how to change out the plugs on these monstrosity of motors. Looks like its gonna take more time and patience than I'm use to having when it comes to doing tune ups. But.... It has to be done none the less. I'm just gonna have to grit my teeth and take it with a little lube.
Old 01-30-2012, 07:05 AM   #8 (permalink)
Mikiedoo's Avatar
Default
Yeah, coils can go bad like that. It will fire ok sometime, then all of a sudden start missing, then go right back to firing fine for a short period. Definitely get it and the plugs changed.
__________________
2001 Expy 5.4L Eddie Bauer 4x4
3" PA bodylift , 2" torsion crank , 2" coil spacers
315 75 16 Nitto Mud Grapplers on 16x10 Wideass Pacer LT polished wheels (-32mm offset ) Tinted windows
Mikiedoo is offline   Reply With Quote
Old 02-01-2012, 07:29 PM   #9 (permalink)
jdan's Avatar
Default
Usually when ever I pull out a misfiring coil the boot has condensation on it.
I've dried them off and put them pack with success of saving a few bucks.
But it's like 50/50 on fixing the issue.
jdan is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
