Gray Ghost Front Diff Change-out
TimmyB
PTC GA
Guys,
Changing out Front Chunk on my 2000 EXP A4WD. Is there just one version of the diff in 2000? Located low mileage unit, however it has a vac. module for two line hook-up on top of the diff, passenger side. Looking at mine from underneath, I see one rubber line, maybe a breather....but no vac. lines/module? I'm I missing something or is the vac. module version for 4WD only?
Need a Tech Guru to advise, any options if there is two versions.
Thanks!
TimmyB
T
TimmyB
PTC GA
Right or Wrong Diff for 2000 A4WD
Attached pic of Diff I was told that would work...2000 A4WD?
Who Knows????
Hampton, VA
welcome to the site...this section is for ppl to give an intro about themselves then find the appropriate section to ask the questions...im sure someone will give input...sorry I cant help
ExplorerTom
It's clunking. It might be too late, but try pulling fuse 104 in the underhood fuse box.
