white smoke
renee
north carolina
I just replaced 4 out of 8 spark plugs on my 99 expedition and i started the truck to it running really bad and white smoke coming from the exhaust the smoke smells like gas and my engine light is now on any suggestions on what it is? The plug for a computer to hook up and read the codes is broke so I can't just take it in
sgtowing
Supporting Members
Valrico, Fl
Welcome. White smoke is a sign of coolant getting in the combustion chamber, usually a sign of a head gasket leak.
R
renee
north carolina
but wouldn't the smoke smell sweet instead of like gas? The third spark plug i had to use a chaser on do u think it is the oil i used to lub the chaser?
toms89
technical advisor
MD
I would say you have a dead cylinder or two if it is running badly after plug change. If it smells like fuel you likely are not getting spark.
Are you sure all cops are plugged in??
Did you gap plugs properly? Are spark plugs firmly seated and torqued?
toms89
technical advisor
MD
What year expy?
Any issues prior to plug change?
R
renee
north carolina
ok i will go back thru them the truck had no problems like this before hand thank you for your help
toms89
technical advisor
MD
Generally white smoke is sign of coolant in combustion chamber but I am going on the basis that the vehicle was ok before the plug change.
